Food for thought - B3S
Old 11th March 2005, 03:13 AM   #1
bzdang is offline bzdang  Canada
bzdang's Avatar
Default Food for thought - B3S
Saw these cookie jars at the supermarket today, couldn't resist.
Benford's law of controversy - Passion is inversely proportional to the amount of real information available.
Old 11th March 2005, 05:36 AM   #2
Dave Jones is offline Dave Jones  United States
How wide is the opening?
Davy Jones
Old 11th March 2005, 05:43 AM   #3
knorke is offline knorke  Germany
knorke's Avatar
That looks promising...
You might consider to coat the inside of the jar
with something that damps the resonances of
the porcelain.....
Old 11th March 2005, 10:04 PM   #4
bzdang's Avatar
The opening was 4.5 inches with a roughly 5 inch step around the hole.
Here's a photo of it with the baffle installed, made from a threaded cap for 4" ABS DWV pipe. It helps to have a lathe or access to one. It's thoroughly stuffed with itchy fiberglass insulation and doesn't ring when I tap on it. It's the focus of my first foray into measurement so I will likely post some measurements when I figure it out.
Subjectively the thing sounds better than I expected for something so small and inexpensive.
Old 12th March 2005, 01:11 AM   #5
knorke's Avatar
I think they will measure quite good...
Keep us informed about the cookie jar speaker ;-)
Old 12th March 2005, 02:06 AM   #6
bzdang's Avatar
Here is a set of measurements by sine sweep, my family is feeling tortured by my new apparatus.
I measured without EQ, with and without mic cal file, and after applying some BSC and two parametric filters to minimize the large peaks at 8.3kHz and 15.5kHz
I can't listen to music until morning so no opinions on the eq'd sound yet. I'm very very interested in learning how to measure phase and to see how badly the digital crossover affects it compared to passive crossovers.
Old 12th March 2005, 02:08 AM   #7
bzdang's Avatar
The EQ, brought to you by kxproject !
Old 12th March 2005, 10:08 PM   #8
Shahin is offline Shahin  Canada
This looks so good! I'm feeling inspired to something with an old fishbowl I have...
Food for thought - B3SHide this!Advertise here!
Harmonic parrot food? StoneT Tubes / Valves 9 30th June 2008 12:58 PM
Some food for thoughts: UniversalX uli Pass Labs 15 15th December 2004 08:25 PM
UN survey on food shortage (joke) Circlotron The Lounge 1 24th September 2004 02:34 PM
Thought of the day.. Sawzall Multi-Way 11 28th June 2001 03:52 AM
