anyone hear a Fostex 206e in a back loaded horn cab.?
Old 7th March 2005, 11:02 PM   #1
audionut is offline audionut
Default anyone hear a Fostex 206e in a back loaded horn cab.?
I built a Voight Pipe cabinet ala the Abby...but rather than install the Foxtex 166e, (as in the Abby) I installed the larger 206e thinking that the base reproduction would be better.
What I got was a very "hot" sounding speaker, even when I implement the filters as recomended by Nelson.
I called Madisound and one of the engineers said that the 206e's QTS is too high for a Voight pipe, but the 206e sounds pretty good in the back loaded horn enclosure whose plans come with the driver...
So my question is, has anybody heard this driver in a back loaded horn enclosure???
Old 8th March 2005, 05:46 AM   #2
grecord is offline grecord  United States
I have It sounds great and is pretty easy to build. Lots of break in time for that driver. Does not smooth out to at least a coulple hundred hours on them. Good luck
Old 8th March 2005, 07:04 AM   #3
Yoghourt is offline Yoghourt  France
FE206E, FE208 sigma nearly have the lowest Qts of all fostex full-range drivers: 0.18. Only FF225K has a lower Qts: 0.16.
I tried and played a little with M.J.King worksheet for ML-TL design, and a low Qts seems to make things less easy.
From what I understood, back loaded horns are "naturally suited" for low Qts drivers.
Seems like "one of the engineers from madisound" tells "left" while he thinks "right"
Dzharis: raaaaaah lovelyyyy!
Old 8th March 2005, 09:24 AM   #4
Nvt is offline Nvt  Viet Nam
Does anybody have plan for Fostex 206E that you think about it is the best sound?
Nvt
Old 8th March 2005, 01:57 PM   #5
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
Take a look at the HP16 deflex panels also. They work great in the 206 BLH.
Old 8th March 2005, 04:21 PM   #6
Josephjcole is offline Josephjcole  United States
Josephjcole's Avatar
If you go over to the fullrangedriver forum, Ron has designed several horns for the 206, you should be able to find the plans there. Supposedly very nice.
Joe
Old 9th March 2005, 05:27 AM   #7
brady is offline brady  Philippines
Default Fostex 206 in RLH
Ya I heard a Fostex 206, in a Fostex-designed RLH. Very very good. The owner/builder is still in the process of "tuning" his pair (aren't we always ? hehehe). He's experimenting with various damping materials to attenuate a squawk in the upper mids.
I just got a pair of 206 from Tim and intend to build an RLH, similar to the Solo 206 of Tony Gee(a little taller, but slimmer than that of Fostex). That way, we'd be able to make comparisons.
I already have a pair of Fostex 208 Sigma (not anymore available in their catalogue) in a RLH. Paired these with Fostex T90A, cut (as of this time) with 0.25uf
Hope this helps.
Old 9th March 2005, 10:20 AM   #8
lufbramatt is offline lufbramatt  United Kingdom
lufbramatt's Avatar
we have built a pair of the fe206e cabs recommended on the fostex site, and they are the most natural, transparent things i have ever heard, although they have a distinct lack of bass. The pair we built have probably had about 150-200 hours on them now and seem to be settling down a bit.
stereo imaging is superb and the highs are very smooth, not at all harsh. The owner really likes them, but i think they may be a little rolled off, but playing with a signal generator i can hear about 1.5khz higher than him anyway.
they are powered off a 250 valve amp from the Affordable Valve Co, (dynaco st70e i think ) and they sound really good. After a recent trip to the bristol hifi show, tbh they equalled or bettered any of the systems we heard there. Not bad for about 250 of materials (inc drivers) on a cheap valve amp . . . they are a bit fiddly to construct but def. worth the effort imho.
last night we finished the construction of a huge sub using a shiva driver that we found by chance on ebay- should make all the difference
Old 9th March 2005, 01:47 PM   #9
resident is offline resident
Account Disabled
lufbramatt
You mean the RLH reccomended cabs,right?
Not the BR?
Because I'm also interested to build Fostex recommended BLH enclosure.But they're a little bit difficult.
For a simpler solution I think MJK's design is better.But I'm not sure what to do,yet.
Old 9th March 2005, 03:10 PM   #10
lufbramatt's Avatar
resident- yes we did make the blh cabs, exactly the same as the ones in the pdf u attached. The internals split down into 3 "L" shaped sub assemblies, so as long as u get them square theyre not that hard to make. The biggest problem we had was sourcing 21mm ply, we ended up laminating a sheet of 12mm and 9mm ply together.
All the parts for one cab fit onto 1 sheet of 1220x2440mm ply, with a tiny bit left over, i can probably post our cutting plan up if i want.
anyone hear a Fostex 206e in a back loaded horn cab.?Hide this!Advertise here!
fostex 206E back loaded horn failure gerado Full Range 76 21st May 2009 08:59 AM
DIY Back Loaded Horn - Dallas III for Fostex 206E jasonlky Full Range 46 6th April 2008 11:50 PM
Copyright ©1999-2017 diyAudio
