Old 14th March 2005, 09:57 PM   #21
Illusus is offline Illusus  Canada
Illusus's Avatar
At the moment I'm stuck due to a funds shortage. I put my Dynaco PAS2 hot-rod pre for sale on ebay, when it sells I'll be able to finish all my projects(I hope). Right now I'm using the time to design the line level XOs and BSC...I'm making the BSC variable so I can adjust if I move to a different room. Also, I'm waiting on veneer, working on the cage and grill for the back of the OB, designing a chassis and layout for a BLS(BOSOZ) and some ZEN4s...tons of ****. Sorry for making you wait . I say go for it, the OB sounds damn good to me and is not that hard to try, all you need is to fill in the bottom end somehow. Anything specific you're curious about?
Fighting the program since 1976.
Old 14th March 2005, 10:11 PM   #22
Just wanted to see how the whole thing panned out. I think I may have to wait a little bit, as I need funds to get LF drivers. At this point, I'm leaning towards the Fostex FW305 12". I like the fact that it goes low and will still be quick, costs a little more than I had planned, but not as much as JBLs or something.
You seem quite happy, so I think I'm going to go for it. Sounds like you have a lot of irons in the fire. Good luck with the projects, keep us posted!
Old 14th March 2005, 10:30 PM   #23
Illusus's Avatar
I got very lucky with those JBLs. I was pawn shop browsing and saw these two giant 'roadie' boxes I took the lids off and there they were, along with some vintage AlNiCo 2402 horn tweeters, I paid $140 canadian for the pair and sold the tweeters on ebay for over $400 US. I carried that smile for some time, it still pops up...like right now.
Old 15th March 2005, 02:31 PM   #24
Now that's what we call a deal!! Well done! I've never found anything at pawn shops or second hand stores. Then again, I don't look around that much. A truly good score.
Old 15th March 2005, 09:35 PM   #25
planet10's Avatar
That is how i generate a major portion of my meager income -- it is amazing what is out there to be found.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th March 2005, 02:14 AM   #26
Illusus's Avatar
I'm now going to design the PLLXOs. Any tips? I've been toying with the formulii found on Dave's PLLXO page but it seems a touch vague to me, how will this affect Q? . Should I go for 2nd order on the LP and 1st on the HP or 2nd or 1st for both? I suppose I'm fishing for an opinion on what you'd do given my situation. I also suppose I'm being a bit vague myself...anything you guys need to know to be able to help me out a bit?
Old 17th March 2005, 02:22 AM   #27
Illusus's Avatar
I just stumbled on the link to Art Ludwig's couple paragraphs on the subject, it clears up a couple things(surprised I didn't notice it earlier)...also I remember an article in an issue of AudioExpress about somebody making one for their subwoofer, I'll see if I can dig that up.
Old 4th April 2005, 04:22 AM   #28
Illusus's Avatar
A little update,
I designed and implemented a passive line level BSC (RC) with 6db compensation, I tried 3db but due to speaker placement it sounded thin . It worked well to smooth out the bass response, there are still some holes and peaks but that's due to my room, although it has near perfect dimensions it's nearly untreated (except for the furniture), we don't plan on staying here too long so I haven't bothered. The BSC ate up some gain, but it's ok for now.
I also changed the xo. It was parallel, first order on the Fostex, 2nd order on the woofer, now it's first order series, sounds better, much better....there seemed to be a slight dip in the midbass before, the baffle cancelation occured above the xo point, first order on the woofer added the needed lift there. By nature, there should be a bit of combing now, but it doesn't seem noticeable from my listening position, there's a spot, when I move my head down and forward a couple of feet, where it's very obvious. I still haven't tried PLLXO or active...I'm going full balanced with my system but I'll leave the option for active xo/biamping just so I won't be in the dark.
Also, because I had some spare HQ(hovland) caps from a previous project, I cascaded(four steps) the big cap....I was a little sceptical of this practice but the midrange became a little more real and the highs clearer and more extended. I don't notice any tonal 'steps' as the f goes higher.
That's it for now. I have to wait untill my pre and amp parts come in untill I can try anything new, I sold my pre to fund my projects and have resorted to using my TV's extra I/O as a pre....it's not so good sounding.
200V peak to peak @25MHz ketan Parts 1 8th June 2008 04:21 AM
CES 2006, sneak me in??? lgreen Everything Else 2 28th December 2005 06:53 PM
Question regarding peak in the first maximum of the dipole effect mazeroth Multi-Way 2 14th September 2005 05:21 AM
Sneak peak into my latest project... pics ;) Audiophilenoob Multi-Way 108 27th August 2005 11:19 PM
New Movie Sneak Pics.......... mrfeedback Everything Else 2 7th January 2004 09:59 AM
Page generated in 0.10463 seconds (78.90% PHP - 21.10% MySQL) with 11 queries
