My fostex fe126e experiences - diyAudio
Old 5th February 2005, 08:03 PM   #1
Juspur is offline Juspur  Denmark
Default My fostex fe126e experiences
Hi diy'ers
I just wanted to report, that I've built the fostex-recommended basreflex-design for the fe126e. The background for this report is the general lack of information for fe126e-designs.
Before I started, I wondered whether I needed a parallel notch filter to dampen the 6,5 kHz peak - but decided to give it a listen first.
I've no previous experience with full-range driver, but was afraid that it could be nasale and with too much energy is the upper frequencies.
To put it short, I had absolutely nothing to worry about: the sound is very balanced, delicate - and with an extreme musical timing and natural amount of details - you definitely won't get bleeding ears - I just kept listening to cd's all night long (and today too). The tonality is musicality is absolutely setting a very high standard.
The only backdraw is off course the limited bass, but I don't feel I'm missing anything, according to the timing and quick response overall.
My cd/amp/cable setup is very neutral, and in the $6000-league. I've scrapped my other speakers (at $1400/pair).
The fe126e-design is at $200/pair, including enclosures.
Old 5th February 2005, 09:33 PM   #2
johnb is offline johnb  Sweden
Nice work, that MDF is it used for bracing?
Old 5th February 2005, 09:42 PM   #3
Wow. Bested some high dollar ones and scrapped em, eh?
Can I have em? Just kidding. Good for you.
I wonder if anyone participating in the 127E "reference TL" thread has any comparative experience. Have you looked thru that thread? MarkMc might have some info for you.
Thanks for posting.
onasis
Old 6th February 2005, 08:32 AM   #4
Well, I bought some cheap bookcases - the MDF was necessary for the sides of the enclosures (the one side is glued on the original back of the bookcase, the other is glued on a frame just inside the enclosure.
Old 6th February 2005, 08:32 AM   #5
Onassis: thank's for the hint - I'll check that (long) thread once again.
Juspur
Old 6th February 2005, 09:30 AM   #6
frugal-phile(tm)
planet10's Avatar
creative cabinetry -- i love it... they look quite sharp :^)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th February 2005, 08:58 PM   #7
Timn8ter's Avatar
I love it! That proves you don't have to have a full-blown workshop to successfully DIY.
Old 6th February 2005, 09:39 PM   #8
frugal-phile(tm)
planet10's Avatar
you just need to think different
dave
Old 8th February 2005, 10:52 PM   #9
Illusus is offline Illusus  Canada
Illusus's Avatar
Looks fantastic. Congratulations.
True DIY'ers see potential in everything.
Fighting the program since 1976.
Old 12th February 2005, 08:51 PM   #10
Well, it's not exactly a boom box. Fostex recommends a 11,5 cm long port (Ø 5 cm). I played around with boxplot - see below:
Well, -3 dB at 200 Hz, -5 db at 150 hz, flat until 61 Hz, rolloff. It must be possible to come up with something better.
This is better. Port length = 4,3 cm, -3dB at 150 and 80 Hz, with rise to 0 db at 90 Hz. I still don't like the -3 dB at 150 Hz, so here we go again:
Port length = 3,2 cm, -3 dB at 80 Hz.
...And the sound? Well, the last solution is absolutely the best - you can feel the bass in the floor + a very coherent sound. Try it!
Fostex Fe126e in BR audiophile36 Full Range 30 16th February 2009 07:21 PM
FS : fostex fe126e Cacophonix Swap Meet 4 22nd August 2007 10:57 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 01:35 PM
WTB : Fostex FE126E Cacophonix Swap Meet 0 27th February 2006 03:52 PM
Copyright ©1999-2017 diyAudio
