zobel networks and imoedence reduction?
Old 19th January 2005, 07:27 PM   #1
Nanook is offline Nanook  Canada
Nanook's Avatar
Default zobel networks and imoedence reduction?
It seems to me that the bass output of full range drivers is seriously affected by the rising impedence as the driver reaches fs.
What can be done to reduce this rising impedence? A Zobel? Will this increase the output at or near fs? Has this been used in horns or other single driver, high efficiency speakers?
What are the other alternatives?
Any and all help appreciated as always.
stew
Old 20th January 2005, 01:25 AM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
A "Zobel" will not generally increase the bass coming out of a
speaker. A current source or other high impedance amplifier
will increase the bottom end - if that's what you're looking for,
and in that case a resistor can be used to trim the damping of
the system.
Check out the article on www.firstwatt.com
Old 20th January 2005, 01:30 AM   #3
rdf is offline rdf  Canada
rdf's Avatar
Assuming it's really a problem for the amp, the hard road is to add a tuned series LCR string in parallel with the woofer to flatten the peak. This is probably practical only for a driver/cabinet system with a single impedance rise. The double hump impedance curve of a bass relflex would make for some challenging optimization.
However, there's a much easier way to determine if it's worth pursuing: parallel the woofer with a resistor. 100 ohms in // will drop 8 ohms to 7.5 (miniscule) and a 50 ohm rise to 33 ohms (significant). Or, for full effect, test it using 12-15 ohms, which will drop the typical ~6 ohm mid-band impedance of a full range to 4 ohms and give it a whirl on the 4 ohm secondary taps. From the results decide if the full meal deal's worth the trouble.
Old 20th January 2005, 01:59 AM   #4
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Default Re: zobel networks and imoedence reduction?
It is not. Put the entire concern out of your mind and shift your focus elsewhere.
Old 21st January 2005, 08:33 PM   #5
tenderland is offline tenderland  United States
tenderland's Avatar
Default full range
This link may provide some info
I am a nub my self and just completed a pair of full range speakers
http://www.quarter-wave.com/General/BSC_Sizing.pdf
Jeff
zobel networks and imoedence reduction?Hide this!Advertise here!
Biamping and Zobel Networks Won Multi-Way 38 11th October 2014 02:23 AM
Zobel networks Skeebopstop Class D 7 15th June 2009 07:04 AM
About snubbers(Zobel networks) CECCO Chip Amps 0 15th June 2008 09:40 AM
How do I parallel T networks? classd4sure Class D 25 5th October 2006 05:48 AM
building zobel networks zuki Parts 0 27th August 2006 05:52 AM
