4"x8" Port = two 4"x4" Ports for MLTL??? More Complex???
Old 16th January 2005, 10:44 PM   #1
OTMOPO3OK is offline OTMOPO3OK  United States
Question 4"x8" Port = two 4"x4" Ports for MLTL??? More Complex???
Hi, i'm almost done with the sub and the port is the only thing that separates me from it.
It's a Mass Loaded TL and originally i was gonna use 4"IDx8" port with 3/4"flare on both sides but now i only have 2" of space behind the port and back wall of the line. I think it's too little! Yes/no?
What are the rules for breaking port volume in two ports for MLTL.
If only the mass of air inside the port matters then does it mean i can just saw it in half and have 2 4"IDx4" ports side by side?
Or is there a special formula like for regular BR which takes the inside surface area and friction of air into account and the actual volume has to be bigger?
Please advise ASAP, i can't wait to listen to the sub
Thank you very much!!!
PS.Yes, I've searched and haven't found an answer.
Edit: i put this into FR forum because more ppl make TLs here and since it's a general question about ports (not sub specific).
Old 17th January 2005, 03:28 PM   #2
Josephjcole is offline Josephjcole  United States
Josephjcole's Avatar
The two variables are the effective port cross-section and the length of the port. the narrower the diameter the shorter the port can be. The larger the diameter the longer it has to be. Changing one 4"x8" port into two 4"x4" ports doubles the effective cross-section and halves the length. This would raise the tuning frequency of the box by quite a bit. I would suggest using a 4"x8" port with a 90 degree bend in it.
Joe
Old 17th January 2005, 03:58 PM   #3
Thank you i think i figured it out
Regular rules apply, Doh! ((C)Hommer Simpson)
I decided to try 7" port with the extension due to close proximity of the back wall.
4"x8" Port = two 4"x4" Ports for MLTL??? More Complex???Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 05:53 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
