hello, my first fostex fullrange.. whit fe107. Bass reflex, 6 lt, mdf 16mm+plywood 3m. souds good:)
M mantonto Member Joined 2004 antoaudio.altervista.org/ 2005-01-05 1:00 pm #1 2005-01-05 1:00 pm #1 hello, my first fostex fullrange.. whit fe107. Bass reflex, 6 lt, mdf 16mm+plywood 3m. souds good Attachments littlefostex4.jpg 33.3 KB · Views: 322 ••• More options Share M mantonto Member Joined 2004 antoaudio.altervista.org/ 2005-01-05 1:03 pm #2 2005-01-05 1:03 pm #2 another pic Attachments littlefostex7.jpg 84.1 KB · Views: 322 ••• More options Share Timn8ter Member Joined 2003 2005-01-05 1:54 pm #3 2005-01-05 1:54 pm #3 Using a down firing port is a nice adaptation. It appears there is no port tube, correct? Did you make a change to the port diameter as well? ••• More options Share M mantonto Member Joined 2004 antoaudio.altervista.org/ 2005-01-05 2:37 pm #4 2005-01-05 2:37 pm #4 Et voilà, the port tubes ( 5x9,3 cm): Attachments evoreflex.jpg 35.1 KB · Views: 273 ••• More options Share Timn8ter Member Joined 2003 2005-01-05 2:49 pm #5 2005-01-05 2:49 pm #5 Molto buon! ••• More options Share M mantonto Member Joined 2004 antoaudio.altervista.org/ 2005-01-05 3:48 pm #6 2005-01-05 3:48 pm #6 Molto buon! Click to expand... ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
