cabinet construction
Old 7th January 2005, 06:50 AM   #11
thayerg is offline thayerg  United States
practice never hurts. Neither does figuring out a glue-up strategy before you've spread the glue out--trust me on that one!
I'd only use pvc if you can really smooth out the exposed end, otherwise it's going to look cheesy at best. Either that or cut the cabinet hole to the inside diameter of the pvc and mount the pvc on a flange attached to the cabinet wall, which might not be a bad way to go because you could then experiment with different port lengths before using sealant. Assuming you'd want to.
Old 7th January 2005, 07:23 AM   #12
DIAR is offline DIAR  Finland
DIAR's Avatar
What kind of filler is fool proof for mdf cabinets. I'm going to paint my next speakers and I don't wan't to see any cracks or dents after few years.
Old 7th January 2005, 01:53 PM   #13
Sherman is offline Sherman  United States
Wood filler works well but automotive "Bondo" is cheaper and better if you intend to paint.
--Sherman
Old 7th January 2005, 02:02 PM   #14
tiroth is offline tiroth  United States
Plus Bondo dries waaaay faster.
Old 7th January 2005, 05:55 PM   #15
DIAR's Avatar
yep, I'll use 2-component filler.
Old 8th January 2005, 07:26 AM   #16
Use wax-free shellac to seal the mdf as it won't raise the grain. I also read an article in fine woodworking or someplace where the guy filled the edges of the mdf with drywall compount to smooth it and make it less thirsty. Sounds like a good idea to me--I did an mdf entertainment cabinet and the exposed edges just would not disappear under the primer until I had primed and sanded waaaay too many times.
Old 9th January 2005, 02:52 AM   #17
tenderland is offline tenderland  United States
tenderland's Avatar
Default one down
Well one cabinet done , looks ok fro first one . Did have one BLOWOUT with the brad nailer but it was on the bottom . everyones input was very helpfull . I cant wait to fire them up , hope they sound ok .
Jeff
cabinet constructionHide this!Advertise here!
New cabinet under construction. Andy G Multi-Way 42 23rd June 2008 06:43 AM
Cabinet construction tips needed guillaume Full Range 24 12th June 2005 04:37 AM
Some more info on cabinet construction Yesfan70 Full Range 16 5th May 2005 04:17 PM
housing material for cabinet construction michael Multi-Way 5 11th January 2004 08:16 PM
Shielding Ideas (Cabinet Construction) ??? FrankRoss Multi-Way 4 8th November 2001 12:03 PM
