Old 30th December 2004, 11:21 PM   #1
Default z-680 modding
I just got a z-680 system, and I'm considering doing some tweaking.
The system comes with 5 satellites each with a 3" phase plug driver. Im considering replacing these with similar tang band drivers, but im not sure how much it would effect sound quality.
I've also been toying with replacing the 8" sub driver.
This would be my first project like this, and I would appreciate your input.
Old 31st December 2004, 08:49 AM   #2
hobbes is offline hobbes  Sweden
I believe it is Tangband speakers in the z-680 satellites..
But maybe it is possible to find better models.. (W3-871) ?
BR
Hobbes
Old 31st December 2004, 05:33 PM   #3
they might not be TB drivers...
take one out and take a look at it and post several pics for us to look at...
i'd recomend that you just build some new speakers...i don't think that a plastic shell is going to treat you very well as far as an enclosure goes...
but post some pics of the drivers from the satelites and prove me wrong....maybe they are TB drivers...
Old 31st December 2004, 06:33 PM   #4
Illusus is offline Illusus  Canada
Illusus's Avatar
they sure do look TB-ish, maybe Aura.
There is not much you can do to the driver itself, maybe some rope putty between magnet and basket, felt inside the basket legs., I think those have cast baskets and neo magnets, so no real need to damp the basket or motor assy....
I would look to building some decent enclosures for them instead of modifying the drivers, you'll get much more noticeable improvements that way. At least try some tar based damping materials on those plastic shells, those tiny stands they come with are pretty flexy add a strut to stiffen them up ...that is if you're really not into building some better 'boxes' for them.
Fighting the program since 1976.
Old 31st December 2004, 09:01 PM   #5
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
They are custom-made Tangband drivers, rated at 15W RMS, I think.
Read here, towards the bottom of the page (someone pointed me to this link before):
http://www.dansdata.com/speakersets.htm
KTK. Kool To the Kore.
Old 31st December 2004, 10:40 PM   #6
thomas997's Avatar
I would not replace the speakers or subwoofer, they are probably designed specifically for those enclosures. They all all tangband speakers.
That speaker set is already very good.. maybe there is something else you can mod (all I can think of is stuff the satellites if there isnt any already).
Old 1st January 2005, 12:47 AM   #7
Send a message via AIM to Chris8sirhC
Just order five tb w3-871s drivers and put them in a small box, instant improvement. There is a pretty popular design for those drivers, i just dont have the link right now.
Old 1st January 2005, 02:12 AM   #8
Couple of things
- I recognize the link coolkhoa posted (I've posted it myself a time or two), and it concerns the Z-560s. Sure it demonstrates that Logitech likes to use Tang Band drivers, and they might be the identical drivers in your Z-680s but you shouldn't assume that to be the case. Until you crack your speakers open you can't be sure what they are.
- The built-in amplifier may have a ridiculously high crossover point to the sub - in fact I'd anticipate this. You might do all these extensive mods and find out that the speakers don't see any signal below 250 Hz anyway. I'd borrow some larger speakers and do a test run before proceeding further, with the sub disconnected, so you can find out if it's even worth continuing.
If you get good results there I'll chime in with another vote toward replacing the boxes rather than plopping new drivers in those tiny enclosures.
This might be the link Chris8sirhC was thinking of:
http://home.new.rr.com/zaph/audio/audio-speaker11.html
Don't just look at the first pic and decide, there are plans for several different enclosures down the page including one very compact setup that seems very appealing for a typical computer desk.
Old 18th January 2005, 12:44 AM   #9
Just wondering, does anybody know who makes the sub driver?
(same as posted here http://www.diyaudio.com/forums/showt...&postid=554406)
Old 7th May 2005, 10:04 PM   #10
Angaria is offline Angaria  United States
Default How to use a "Z" sub with floorstanders
Is there a way to eliminate the crossover on the sub? (basically I want to send all frequencies to the satellites) I currently have 2 channels going out to a couple of Athena AS-F1 floorstanders, but the sub sounds like it's cutting off everything <200 Hz.
Idealy I'd like to have it kick in <50 Hz, but that's probably asking a lot, although this is the only forum I've found where people are modding the z-series substantially.
I'm on a tight budget at the moment, so I'd like to avoid buying an integrated amp, which is why I'm trying to do this. Alternately, if I do have to buy one, it would be nice to use the sub to fill in the bottom end some how...
Let me know what you think, thanks.
(the z-2200 sats. are the same as the z-680 ones.
NAD PP1 modding, psu and others Psychobiker Analogue Source 6 15th June 2009 08:39 PM
Modding a GDA-700 ben62670 Digital Source 2 22nd August 2008 01:53 AM
Modding the x-mod ionomolo Digital Source 0 4th September 2007 04:38 PM
Page generated in 0.11942 seconds (79.30% PHP - 20.70% MySQL) with 10 queries
