Old 20th December 2004, 07:15 PM   #1
JimW is offline JimW  United States
Default fostex 206 in 2.5 cubic foot box
I have a pair of 2.5 cubic foot boxes collecting dust, and was considering put a 206 in each of them. How would the work in a reflex enclosure? The boxes are 18 x 24 x 14 deep.
Jim
Old 20th December 2004, 11:51 PM   #2
drongo is offline drongo  Australia
Default Fostex 206 in 2.5 cubic foot box
Fostex recommend a 45 litre cabinet, so 2.5 cubic feet (approx. 70 litre) is much bigger. I think smaller would certainly be better.
Have a look at this http://www.tnt-audio.com/clinica/bfb_e.html
Old 21st December 2004, 12:12 PM   #3
MPM is offline MPM  United States
Check out the cabinets on this site. They have one about the size of what you want. The porting they use is the key.
www.fostexspeakers.com
Old 2nd January 2005, 09:13 PM   #4
Default Re: fostex 206 in 2.5 cubic foot box
Originally posted by JimW
I have a pair of 2.5 cubic foot boxes collecting dust, and was considering put a 206 in each of them. How would the work in a reflex enclosure? Thanks
Jim
They would be boomy in the extreme.
In a sealed box that size, the speakers would be extremely over-damped.
You might be able to put some partitions in the box to turn it into a back horn. I don't know if they are a good size for that or not.
Assuming the inside height dimension is 22", you could put partitions in the box to turn it into a 44" tube. Add a 4" diameter port 6" long at the end, and you have a mass loaded transmission line. But it would have a 6 db shelf at about 300 Hz. To kill that, add 8 ohms series resistance. Use some polly fill stuffing, but not too close to the port. I did a quicky using Martin's worksheet. You can probably do better by tweeking around with it. See chart.
Davy Jones
Old 2nd January 2005, 09:30 PM   #5
Check this one out.
Davy Jones
Old 2nd January 2005, 09:31 PM   #6
Originally posted by Dave Jones
Check this one out.
Zport should be 41 inches. Note, this has 8 ohms series resistance added.
Davy Jones
Old 5th January 2005, 05:50 PM   #7
The one and only
Nelson Pass's Avatar
Default Re: Re: fostex 206 in 2.5 cubic foot box
About the time you decide to add that much resistance, you
might as well go to higher source Z and get the bottom end
out of the existing sealed box.
Calculating box dimensions from cubic volume retroman Multi-Way 6 11th July 2009 04:06 AM
12" XLS in a 3.5 cubic sonotube? speakrsrfun Subwoofers 4 29th March 2009 02:05 AM
Question about cubic feet drumsz Subwoofers 2 11th November 2008 11:39 PM
Q's about Cubic feet and driver selection evad Subwoofers 2 11th October 2007 03:37 PM
Page generated in 0.09064 seconds (75.21% PHP - 24.79% MySQL) with 11 queries
