#681 | |
Scott |
#682 | |
My Bipole needle, and your thoughts. |
#683 | |
Scott |
#684 |
I wanted to build the Needles about 1.5 years ago and read the whole thread here mostly because I wanted to find some opinions about currently available drivers as the Tang Bands Cyburg originally published the project with are not easily available anymore.
At that time there was only one posting suggesting Mark Audio Alpair 6 and I spontaneously decided to use it. I built the boxes with plywood (and not MDF) using 3/4'' thickness for the walls and preserving the internal parameters given in the original project. I'm posting some "making of" pictures. This was the perfect DIY project doable in a small Manhattan apartment requiring no more than 10 sq ft for about 2 weeks. Btw, the boxes are also perfect in size for that kind of apartments and have a very high SAF (spouse acceptance factor). Sound: Having no conscious experience with full range drivers before, I was surprised how full the sound picture came out even with my (at that time) Kenwood receiver which I got for $20 over craigslist and the cheapest cables bought for $1 of the Chinese $.99 shop. Meanwhile I listen to the Needles using a hand made Class A SET tube amplifier and wonder how people can listen to their cheap commercial systems. In fact my wife was initially skeptical about the sound and I was very pleased when she was talking even months after the Needles were working how she rediscovers our music every day. :) I just wanted to inform anyone interested in playing with the idea of building the Cyburgs Needles that the Mark Audio drivers fit very well into this project. Thank you to Cyburg (Danke Bernd!) and to this forum for the whole invaluable information! :) Last edited by betso; 29th February 2012 at 03:30 AM. |
#685 |
Hi everyone.
Got my "needle" since about 5 months, and I'm SO satisfied. I changed something from the very beginning of the project, because I do NOT like (and my wife,too...) the driver placed on the top of the baffle... ![]() Different positioning of internal woodpanels have maintained the volumetric/transmission line configuration, so I think (and hope) to have kept the same sound Well, I keep them connected to an hybrid amplifier I built just one month ago: ![]() The PRE section has a low-voltage ECC86 Siemens tube, Audyn input and output caps and a linear DC PSU set to 14.1V; Alps mono potentiometers to separately set the input level for the two channels. The POWER stage is a UNmodified italian "Fenice20" with the TA2024;original PSU and potentiometer to set the "master" volume. ...easy: 1 unbalanced RCA input and L+R speaker outputs... no more That's the point: the tube is not "enough" to lighten the extremely high "brilliance" of the 2024, so I had the thought of the Zobel cell... I must be too old and "arteriosclerotic"... but could NOT find the "Le" and "Re" TangBand W3-871 values anywhere in the internet .Anyone knows ? ... Last edited by MacDLSA1970; 5th May 2012 at 09:27 AM. |
#686 | |
http://www.dynabel.no/Resource/File/...D_W3-871SC.PDF Sweet looking needles by the way. |
#687 | |
...for both "things" [ p.s. I had to kinda' "match" the (self-builded) furnishing, so I decided for cherry/black |
#688 |
#689 |
Ok, before I do stupid things better ask to the more experienced ...
The Zobel network should take into account the values of the cables used, but I do not know how to integrate them in the calculation If anyone can help me... ![]() I quote here the values of both transducers and cables: TangBand W3-871 Re = 6.6 Ohms Le = 0.75 mH VanDenHul CS122 Hybrid (1.5 m per channel) R (per lead) = 0.58 Ohm (100 m), C (between the two leads) = 32 pF (1 m) Thanks !!!!! Last edited by MacDLSA1970; 9th May 2012 at 08:13 PM. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Cyburgs Needle kit | ebijma | Full Range | 5 | 13th October 2007 10:53 AM |
| Cyburgs-Needle and Cyburgs-Pipe for FRS 8 | Cyburgs | Multi-Way | 20 | 2nd October 2007 08:24 PM |
| TB W3-871s : Cyburgs Needle or Lancetta | rho | Full Range | 22 | 6th October 2005 06:06 PM |
| Page generated in 0.11743 seconds (83.13% PHP - 16.87% MySQL) with 11 queries |
