#641 |
I have built these, testing prooved that using genuine speaker wadding available from maplins electronics worked better. Cut a rectangle the length of the front panel, twice the internal width. Then cut out a square at the top corner from the centre line vertically to the top of the internal panel. When constructing, you will now notice that only a single thickness of the wadding goes behind the driver and double thickness goes into the pressure chamber, naturally packing tighter as it reaches the bottom.
Finally stand finished speakers on something like russ andrews oak cone feet. 2 front corners and 1 rear. This will improve the whole resolution and extend the focused bandwidth. All in all. A beautifull speaker. THANKS ![]() Jason |
#642 |
can you post a photo ? thanks
#643 |
Hi everybody,
Iam want to built a pair of these nice needles for my girlfriend but i dont know where to find TB W3-871s, can you help me Thanx Thibault |
#644 |
hey everybody,
I want to built a pair of these nice speakers for my girlfriend because. Where can i find the TB W3-871s? Thanx Thibault |
#645 | |
Try spectrumaudio.de or lautsprechershop.de -- but the drivers Omnes BB 3.01 or Mark Audio Alpair 6 are better in this speaker anyway! |
#646 |
The alpair 6 is too expensive for me. The Omnes is much better than the TB or it is very similar? Can i use the Omnes with the original needles plan or i have to change it?
#647 | |
I had good experience with these guys in the past |
#648 | |
The actual build of the box is exactly the same. The notch filter may be a difference ... (Detail: The Omnes drivers don't need the notch filter as much as the TB W3-871 drivers do, so you can skip it. If you want a notch filter then you need different values ... HenkJan of juoiga.nl posted a filter for the Omnes somewhere around here.) |
#649 | |
bb301.pdf needle_filter_bb301.jpg |
#650 |
Thanx for the advices.
Iam also hesitating with chr70 (not for needles). Are they better than the omnes?? Sorry for my bad english |
| Cyburgs Needle kit | ebijma | Full Range | 5 | 13th October 2007 10:53 AM |
| Cyburgs-Needle and Cyburgs-Pipe for FRS 8 | Cyburgs | Multi-Way | 20 | 2nd October 2007 08:24 PM |
| TB W3-871s : Cyburgs Needle or Lancetta | rho | Full Range | 22 | 6th October 2005 06:06 PM |
