#41 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#42 | |
frugal-phile(tm)
Bluetack is probably best of what is on hand... plasticine will harden up (but it takes quite awhile -- it is also more colorful -- that is plasticine i used on the dubloons. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#43 |
Good morning Dave. I have been busy as you can see here.
Last night, the cones got two coats of diluted white PVA glue. First job this morning was to thoroughly clean the basket and magnet with isopropanol alcohol. Then I took some thin self-adhesive cork and stuck it to the underside of the four spider legs. You can just see the cork and apologies for the out of focus shot. Next I moulded the Milliput between the magnet and basket before adding the Bluetak which as you can see doesn't have to be blue any more! While I had the drivers out, I also added some of the self-adhesive cork sheet to the divider panel that comes just behind the driver. I have also done another mod but I may not get permission to show it. Finally, I made some damping for the whizzers. It looks pretty rough in this close up but it's damn difficult to cut that foam so small! And the results? Well, the Milliput is still hardening but there is a clear improvement all round. There is still a slight sibilence on female voices but overall, I would be proud to demo these speakers in any company, bearing in mind of course how much they have cost me! I had to buy the coloured Bluetak so the cost has risen to £1 although I have enough Bluetak to do quite a few more drivers! I hope that I still quality as a Frugalphile!
#44 |
Speakerholic
Right on Nuuk.
Cal |
#45 | |
Thanks Carl.
#46 |
Oops, sorry I meant Cal.
#47 | |
frugal-phile(tm)
The female voice thing may require a dustcapectomy.... and then look around for some dowel, lipstick container, socket head. pen cap -- even a pile of felt for a phase plug. dave
#48 |
frugal-phile(tm)
Did you actually coat the cone or just the whizzer?
dave
#49 | |
Presumably, I use a sharp scalpel and cut round the base of the whizzer. How do I fix in the plugs?
#50 | |
frugal-phile(tm)
http://homepage.mac.com/tlinespeaker...4-surgery.html When you do the plugs you want the tip to reach out just beyond the edge of the whizzer. dave
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Cyburgs Needle kit | ebijma | Full Range | 5 | 13th October 2007 10:53 AM |
| Cyburgs-Needle and Cyburgs-Pipe for FRS 8 | Cyburgs | Multi-Way | 20 | 2nd October 2007 08:24 PM |
| TB W3-871s : Cyburgs Needle or Lancetta | rho | Full Range | 22 | 6th October 2005 06:06 PM |
| Page generated in 0.11729 seconds (76.13% PHP - 23.87% MySQL) with 11 queries |
