#381 | |
Very Nice! I was thinking of doing the same thing (Sand filled chamber underneath,) AS I have cats, and a boy that will be crawling / walking soon. But I think I may have to make a wider base for them when all is said and done. Did you build with Ply? Mdf? What did you use for filling / smoothing the entire cabinet? |
#382 | |
http://www.diyaudio.com/forums/attac...amp=1175359666 |
#383 | |
Greg - what are your reports on the stability of your method? I was thinking of something similar in my head actually. Jon |
#384 | |
How do you find stability? Also - any closer shots / details on how you accomplished this? THanks! Always love seeing your builds. Jonathan |
#385 |
Hi !
In Spectrumaudio I see Needles kits (drivers and filter parts) with W3-871 and W3-315. Anyone compared this 2 drivers ? Differences in sound ? I have pair of Needles with FR8, built last winter, time to upgrade. Hard to decide, wich one to order. Zigis |
#386 |
I would order the w3-315sc, it has a much clearer mid and high.
Especially the high tones are important to me (for jazz and classical music) But it's a close call I guess... |
#387 |
Hi hpolkerman,
thanks for answer. Are you compare both drivers in your Needles ? What is diference in LF ? I see 871 are 3 db more efecient. I try 82 db FR8 with my 2W SET, good only for late night listening. Mayby 88 Db 871 I can try with T-amp ? Anyone try this combination ? Zigis. |
#388 |
my needles using w3-871s sounds good with a t-amp and really sings with a LM3578 chipamp... if you are in a small room and loudness is not much of problem, a t-amp is perfect. It needs a good supply though.
/alohka/ |
#389 | |
The T-Amp would probably need new input caps to fully utilize the Needles' nice bass. |
#390 |
I'm using the Charlize and Amp6 with the Needles with a Omnes Audio BB 3.01. This combination is perfect for lower volumes.
I don't know what the Needles do on bigger amps. It seems to me that the T-amps reach pretty much the limit of what Needles can handle... |
| Cyburgs Needle kit | ebijma | Full Range | 5 | 13th October 2007 10:53 AM |
| Cyburgs-Needle and Cyburgs-Pipe for FRS 8 | Cyburgs | Multi-Way | 20 | 2nd October 2007 08:24 PM |
| TB W3-871s : Cyburgs Needle or Lancetta | rho | Full Range | 22 | 6th October 2005 06:06 PM |
| Page generated in 0.11745 seconds (76.89% PHP - 23.11% MySQL) with 11 queries |
