Old 29th October 2006, 02:15 PM   #181
gychang is offline gychang  United States
Apa's DIY
Originally posted by lohk
gychang, just in case you did find the according pdf yet, here a copy to gif of the w3-871 datasheet:
thanks, great!
gychang
Old 31st October 2006, 07:17 PM   #182
AdamThorne's Avatar
Could someone give me some details about routing to open up the space around the driver to let it breathe?
I wonder if clearing out this space leaves less wood for your speaker mounting screws to grab into... is this a problem? Is there any trouble about decreasing the strength of the speaker face in this area? When you clear out this space, approx what angle have people been using to cut it back at? (call 90 no cut - people like it steep, like 60 or 70 degrees? and even 45? Shallower?) Would making a smooth transition to the flat inside of the panel be worth the effort, or is a hard transition acceptable?
I'm considering using a dremel to carve out spaces around the mounting screws, leaving thick board running up to the driver in those areas for mounting strength and panel vibration control. Also I consider trying to make a nice rounded space through here, leaving no sharp edges where the driver will be radiating backward into the box.
Does this sound like it would be worth the effort? Perhaps I will eventually construct multiple boxes in order to examine this issue. But if any of you can save me the work by just telling me that would be cool.
- Adam (noob)
Old 31st October 2006, 07:24 PM   #183
hm is offline hm  Europe
hm's Avatar
for small speaker try:
cut out larger than the driver,
glue the driver B or FL on
3-4 mm aluminium,
8 srews hold the felt
alu baffle.
like my TROMBONE
http://www.hm-moreart.de
Old 2nd November 2006, 11:20 PM   #184
Apa's DIY
Originally posted by ervington
And the finished product. Finished with four coats of Tung Oil. Continually amazed at the low end of these things.
http://static.flickr.com/50/147883768_8aee10a151.jpg
http://static.flickr.com/47/147883767_9398542c67.jpg
nice, do u feel subwoofer is necessary for this classic and jazz fan?
thanks,
gychang
Old 2nd November 2006, 11:33 PM   #185
Apa's DIY
Originally posted by Bjohannesen
it could be interesting if one of you built my TABAQ and compared it to the Needle. It is very easy to put together, as I have made it as simple as possible.
Please take a look at
http://coolcat.dk/bjoern/TABAQ_TL_for_TB.pdf
Hi from Bjorn
Bjorn: what do you expect will be the benefit of your design compared to the needle, besides obvious difference in cabinet configuration.
I am considering getting the TB speaker but am not sure which design I should consider.
gychang
Old 3rd November 2006, 07:39 AM   #186
Hi gychang
I have just tried to make a speaker as simple as possible and with the best possible frequency repsonse with this nice TB drivers.
I have never heard Needle, and can not say if my design is better or not. I have compared Needle and TABAQ using MJK simulations software. This shows TABAQ has a more flat frequency response. Furthermore, I have not tuned the cabinet fundamental as low as Needle. TABAQ is tuned to 55 Hz, which I found was the lowest fundamental the TB drivers could manage.
Please note, MJK MathCad simulations is a prediction of the finished result in an anechoic environment. The actual in-room repsonse will be different depending on the actual room and the location of the speaker.
Hi from Bjorn
Old 3rd November 2006, 09:19 AM   #187
Cyburgs is offline Cyburgs  Austria
@greenie512,
these are one of the nicest Needles I have seen by now, congratulations!
@AdamThorne:
The most important thing is that the drivers have enough space to breathe. I usually make the cut in about 60°. In this case the screws still find enough wood. Rounding the cut on the inner side can theoretically give an advantage, but I doubt that one can hear the difference. But if you can do the woodwork, do it. It gives a good feeling afterwards.
Nice greetings, Berndt
Old 3rd November 2006, 12:12 PM   #188
Apa's DIY
Hi gychang
Hi from Bjorn
Bjorn: thanks for your clear explanation, I found your speakers very attractive as a DIY project.
gychang
Old 3rd November 2006, 06:56 PM   #189
Default Routing out Baffles for Cyburg's Needles
Adamthorne,
A couple days ago you asked about opening out the back of the baffle on Cyburg’s Needles.
I used a 45 degree ½ inch chamfer bit with a guide bearing. Because I had routed out a recess running the bearing on the remaining thickness wouldn’t have given much of a chamfer (see right router bit in diagram attached).
I therefore cut a hole in some scrap the same diameter as the speaker hole using a home-made router compass, put it underneath the baffle and ran the bearing round it (see left router bit in diagram attached).
The photo under the diagram shows a test piece I made. You can see I’ve left material around the bolt holes. The pencil circles are approximately ½ inch diameter. These are a visual ‘stop’ when routing.
I don’t think this weakens the baffle much. There’s plenty of material left for whatever small compressive load you get from 4mm bolt.
If you need any more information please ask.
Mark
Old 3rd November 2006, 09:18 PM   #190
AdamThorne's Avatar
thx, mod-sonic, that's just what I was planning to do by hand with a dremel... =)
Cyburgs Needle kit ebijma Full Range 5 13th October 2007 11:53 AM
Cyburgs-Needle and Cyburgs-Pipe for FRS 8 Cyburgs Multi-Way 20 2nd October 2007 09:24 PM
TB W3-871s : Cyburgs Needle or Lancetta rho Full Range 22 6th October 2005 07:06 PM
Page generated in 0.13847 seconds (51.19% PHP - 48.81% MySQL) with 11 queries
