Old 18th September 2005, 09:30 PM   #101
Originally posted by revell
I just finished painting my needles, so it's picture time.
Hi gloss white paint makes them look like expensive design speakers
Hi gloss white is great. Here's my JX92's
Old 18th September 2005, 10:39 PM   #102
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
Can you just use john krutke's (zaph) TB w3-871 correction network for these needles or is there more to it?
Same question for the hivi-b3s. A more complicated network, that is...
Si fractum non sit, noli id reficere!
Old 18th September 2005, 10:44 PM   #103
jemraid is offline jemraid  United Kingdom
Dear Revell,
Your Needles look realy professional, I hope they are sounding a lot better as well.
Dear Matjans,
There are some details of the circuit for the Tangband/Needle combination at the beginning of this thread. See Berndts first few posts. Though you could use the FRS8 :-)
Regards - Jem
My Frugel Horn Mk3 build [link]
My Needles and Gainclone [link]
Old 25th September 2005, 02:26 AM   #104
Cyburgs is offline Cyburgs  Austria
@revell:
Very nice design, I like white as colour for speakers very much.
@ all Needles fans:
I have good news: The biggest german DIY audio magazine "Klang & Ton" featured in the current issue an article about the needles (and also about the Viech, btw), all in all seven pages, with plans, pictures and measurements. Especially the description of the listening session is very nice.
Your needles are celebrities now. In a way.
You see the two needle versions and the Viech on the bottom left on the title page.
http://www.brieden.de/klangton.html
Nice greetings, Berndt
Old 15th November 2005, 04:15 PM   #105
Relax is offline Relax  United States
How can I modify the Neddles for two tang band drivers? Preferably in the front.
Is it possible to do this at all?
Or should i just build the needle and add another sealed or ported enclosure on top for the second driver?
Also, if using the tangband, should I XO it at 14k and use a tweeter for above? if so, what tweeter is an inexpensive addition?
Old 16th November 2005, 10:31 AM   #106
matjans's Avatar
as of yet i'm using the needles with the tangbands fullrange (no tweet, no sub). I'm planning on using a sub xo'd at ~70hz and a motorola horn tweeter (EUR 5 at a local dumpstore, goes up to 30kHz), xo'd at something like 12-14kHz.
Not fullrange anymore but more like wide-range.
Old 16th November 2005, 02:09 PM   #107
kec is offline kec  United States
kec's Avatar
Relax,
I added a second TB 871 on the rear of the cabinet directly behind the front driver - a bipole arrangement. Right now I'm just testing this configuration. You do need to leave 18"- 19" of clearance behind the cabinet to the wall.
Salas added an Audax $5 tweeter (from Madisound) to his TB3 design which is also a bipole design, see here: http://www.diyaudio.com/forums/showt...262#post731262
I've built the TB3's with the Audax tweeter and it sounds very nice. The tweeter definately adds a much needed top end to the 871.
-Ken
Old 16th November 2005, 03:11 PM   #108
If I were to cross over to a tweeter, would I still want the notch filter on the tangband? I would think not since the notch is above the 14k i would cross at.
I like to hear you can add another tangband, however I would really liek to have it visible from the front. What would adding a sealed enclosure for another tangband directly ontop.
like this:
Or i was thinking maybe XO both TangBand drivers at 14k, and then use a tweeter for on up to reduce comb filtering:
Old 17th November 2005, 12:44 AM   #109
any thoughts?
Old 17th November 2005, 02:27 PM   #110
kec's Avatar
Relax,
I really don't know. Why do you want the second driver on the front???
I guess it will work, but not sure how well it will sound. I'm no expert - especially on TL. Maybe a second 871 can be added under the first.
-Ken
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Cyburgs Needle kit ebijma Full Range 5 13th October 2007 11:53 AM
Cyburgs-Needle and Cyburgs-Pipe for FRS 8 Cyburgs Multi-Way 20 2nd October 2007 09:24 PM
TB W3-871s : Cyburgs Needle or Lancetta rho Full Range 22 6th October 2005 07:06 PM
Page generated in 0.08867 seconds (71.42% PHP - 28.58% MySQL) with 11 queries
