howdy pups, anyone been messing with this one from dayton? - diyAudio
Old 9th December 2004, 07:29 AM   #1
noisenyc's Avatar
Default howdy pups, anyone been messing with this one from dayton?
http://www.partsexpress.com/pe/showd...number=295-330
i've been having some fun with it. anyone else?
also thinking about that fostex horn kit at nadisound but...different drivers fer sher unless i get a revelation from some experienced forum member
-blackie.
Old 9th December 2004, 08:26 PM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: howdy pups, anyone been messing with this one from dayton?
blackie...
the real problem is too many choices.
Have a gander at the full range reference thread
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th December 2004, 08:51 PM   #3
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Here's some Fostex action:
diyAudio Full Range Reference Project
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 10th December 2004, 12:50 AM   #4
noisenyc's Avatar
yessir i was looking at that...
i was thinking FE166e and ft17h as opposed to the ones madisound chose but...i aint heard 'em ya know?
these look better to me on paper than the madisound choices.
and btw the dayton i posted, which oddly no one seems aware of, is pretty dang good.
i put 4 of 'em in a 16" cube, one on each face, with that cute tlwhateva25 tweeter for air....not too shabby!
check out the curves and specs! that wicked 10k peak is not so wicked in practice if you design 'em slightly off axis to your ear, and...just a wee cap for xover!
-blackie.
Old 10th December 2004, 02:40 AM   #5
Zaph is offline Zaph  United States
Zaph's Avatar
I've got a pair of those in my closet. They are a clone of the MCM 55-1855, and I think they are actually made in the same factory, with the same cone and surround. Same response curve. Different frame. They will likely work with any crossover designed for the 55-1855, and there are lots out there.
The response curve drops like a rock at 2300 hz however, so they need to be crossed over low or "creatively" I did an MTM design with a Seas 27TFFC which was a low crossover frequency, and after a bit of digging I recalled Dan Wesnor's creative crossover using a notch filter for baffle step, allowing a slightly higher crossover point.
Oops, I just said the word crossover 4 times in the full range driver forum. Heheh Ok, I'm leaving now.
-Zaph|Audio-
Old 10th December 2004, 03:42 AM   #6
noisenyc's Avatar
Default Re: Re: howdy pups, anyone been messing with this one from dayton?
Originally posted by Zaph
I've got a pair of those in my closet. They are a clone of the MCM 55-1855, and I think they are actually made in the same factory, with the same cone and surround. The response curve drops like a rock at 2300 hz however, so they need to be crossed over low or "creatively"...
hmmm "drops like a rock" i didn't hear that! my tweeter is crossed at like 13k and padded quite a bit, i chose that by ear, it meshed nicely with the top end of the speaker...
-blackie.
Old 10th December 2004, 05:09 AM   #7
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: howdy pups, anyone been messing with this one from dayton?
The MCM 55-1855 i have done some work with... i don't find that they rolled off that quick -- particularily after a bit of modding (blue curve). (in box, uncalibrated mic)
dave
Old 10th December 2004, 12:53 PM   #8
Zaph's Avatar
-Zaph|Audio-
Old 10th December 2004, 01:46 PM   #9
noisenyc's Avatar
Default Re: Re: Re: Re: howdy pups, anyone been messing with this one from dayton?
dave
here's what zaph says about'em on his webpage, this is more like what i heard.
"Using a pair of MCM 55-1855 aluminum woofers and a Seas 27TFFC. These woofers are one of the all-time great values at $13 each. They required a low crossover point due to an early rolloff, which in turn required a tweeter with the ability to cross over low. Aside from that, these woofers are well behaved and sounded excellent at low to medium volumes. The response curve was almost a straight line, but intentionally tilted down a few db across the top 4 octaves. This gave a smooth, warm relaxing sound, particularly in larger or reflective rooms."
a few db tilt across the top four octaves is not a biggie to me. my ears prefer that to a ringing dome...
think these parts express ones sound better than the MCM's
-blackie.
Old 10th December 2004, 05:39 PM   #10
Zaph's Avatar
Default Re: Re: Re: Re: Re: howdy pups, anyone been messing with this one from dayton?
I don't like people misinterpeting my words, so I have to reply. When I said the response curve was tilted down, it's because I intentionally added circuitry to the tweeter crossover to do this. It's not from running the woofer full range - That would sound both dull and piercing at the same time from the rolled off top end and breakup node. I crossed over at about 1800 hz.
The woofers are well behaved, but only below their intended crossover frequency.
To me the PE woofer sounds just like the MCM. No coincedence since they measure the same and are made the same.
If you would like a copy of my design docs, let me know and I'll email it to you.
-Zaph|Audio-
messing with a transformer kanifee Chip Amps 23 6th October 2008 02:37 AM
Questions regarding HiVi M4N and messing with speaker box sizes blackspur Full Range 1 5th September 2008 03:32 AM
Are old stepped attenyuators worth messing with? highbias Pass Labs 6 24th November 2004 07:11 PM
Uh Oh- I've been messing with the simulator again! SteveG Solid State 1 12th June 2002 03:20 PM
Copyright ©1999-2017 diyAudio
