4" or 5" full range driver - Page 3 - diyAudio
Old 8th December 2004, 03:52 PM   #21
synergy is offline synergy  United Kingdom
just thinking about the whole variable thickness route
i seem to remember there being a post a while back from someone who'd done an enclosure shaped like a tulip?
the whole thing was made up from layers of MDF and then sanded smooth
using the same technique a completely different contour could be designed for the inside of the box
another thought that came to mind was that you could infact make them layers identical and put a 3/4" round over on the top and bottom of the inside edge giving a corrugated effect to the inside and diffusing the sound
just a thought
dave
Old 8th December 2004, 04:05 PM   #22
Timn8ter's Avatar
just a thought
dave
....or use a CNC router.
Old 8th December 2004, 04:13 PM   #23
lucky ****!
haven't got any toys like that in my shop just have to make do with a plunge!
dave
Old 8th December 2004, 04:19 PM   #24
Timn8ter's Avatar
lucky ****!
dave
I don't either but there are places that will rent you the time. On the other hand, if you don't mind putting in the time just make a jig and have at it!
(btw, that's an interior shot of Steve Margolis' Nonsuch loudspeaker system.)
http://www.seventh-veil.com
Old 8th December 2004, 05:19 PM   #25
frugal-phile(tm)
planet10's Avatar
Andy Graddon built a set of tulips... e is alergic to retangular boxes
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th January 2005, 08:11 PM   #26
Default New Gallo 3" Micro T
Anthony Gallo is showing a new micro ball at CES right now (the new Micro T). It is a 3 inch full range titanium driver with a paper dust cap. He claims it is very flat to 22K. It is mounted in a 4" ball and will be $400 the pair retail. He has a powered $400 sub that he is showing with them at CES. Apparently only 1.5 grams moving mass. Anthony says in some ways he prefers them to the Referece IIIs. The sub has a 200uf cap and .1 bypass that goes to the micros that cuts them off around 100hz....the sub does the rest.....of course you can run them wide open but power handling would be diminished as well as I would think clarity with all that bass bouncing around in the sealed balls. Cannot wait to get a pair and play. 4 of them in a mini line source would be nice. If you are at CES I would check them out (Anthony says it will be mind blowing).....driven by a 15 watt a channel $129 Teac? shelf system.....he he. fun little things.
Old 6th January 2005, 04:07 AM   #27
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default Re: New Gallo 3" Micro T
Originally posted by Ric Schultz
He claims it is very flat to 22K. It is mounted in a 4" ball and will be $400 the pair retail....4 of them in a mini line source would be nice. .....driven by a 15 watt a channel $129 Teac? shelf system.....
$1600 ($400 x 4) of speaker driven by $129 amp...kinda odd.
...still looking for the holy grail.
Old 6th January 2005, 04:33 AM   #28
Default Gallo 3 inch full range
The four balls per side was just my idea of fun (mini line source).....Anthony Gallo is demoing just one pair of balls with woofer ($800 total retail) with the shelf system at CES......What I want to do when I get a pair is hardwire them directly with great wire (no binding posts on any speaker I have had since 1979) and also try cutting the ball in half and mounting it to a 5 inch diamater damped PVC pipe maybe a foot or so long so the back wave is slowly absorbed and also has a port of some sort in the rear so the ball is not in a sealed box....I am looking for maximum transparency. One of the best speakers I ever heard was 9 three inch damped Audax full range drivers in series parallel/line source with a couple of modified Fostex ribbon tweeters crossed in about 10K.....sounded like a super modified full range electrostat with incredible dynamics....maybe I can convince Anthony to let me have 18 of them to try it.....he he.
Old 6th January 2005, 08:07 AM   #29
navin's Avatar
Default Re: Gallo 3 inch full range
...One of the best speakers I ever heard was 9 three inch damped Audax full range drivers in series parallel/line source with a couple of modified Fostex ribbon tweeters crossed in about 10K.....sounded like a super modified full range electrostat with incredible dynamics.......
any particular brand or DIY?
Old 6th January 2005, 08:11 AM   #30
navin's Avatar
.......What I want to do when I get a pair is hardwire them directly with great wire (no binding posts on any speaker I have had since 1979) and also try cutting the ball in half and mounting it to a 5 inch diamater damped PVC pipe maybe a foot or so long so the back wave is slowly absorbed and also has a port of some sort in the rear so the ball is not in a sealed box....
the drivers might not like the loading. i think gallo has his drivers custom made for his boxes. i suspect he first came up with an acceptable WAF solution and then designed the system around this. most of us (incl all my systems) get the drivers we can afford first and then build boxes. the result usually does not very high WAF. It was WAF that got me thinking fullrange.
SEAS X1-08 Exotic F8 8" full range driver jackfish Full Range 6 16th March 2009 09:48 PM
Akai 3"full range driver gaborbela Swap Meet 15 14th November 2008 10:10 PM
3" or less full range driver, no filter notacop Full Range 32 30th June 2008 04:30 AM
UTAH 8" Full range driver Kazik Full Range 1 22nd April 2007 03:19 AM
Anyone modded the PE #295-010 full range 5" PA driver? rcavictim Multi-Way 6 30th October 2004 03:29 PM
Copyright 1999-2017 diyAudio
