diyAudio Full Range Reference Project
Old 7th June 2012, 08:15 PM   #861
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
A good coat of PVA is cheap easy and effective. I wouldnt like to try it on a fragile cone though lol
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 4th November 2012, 01:08 AM   #862
freax is offline freax
freax's Avatar
Whats the replacement for this speaker if the driver (FE126/FE127) is no longer being manufactured?
Is it this?: http://diyaudioprojects.com/Drivers/FE126En/
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 4th November 2012, 01:34 AM   #863
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
FF125wk is closest.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th November 2012, 06:06 PM   #864
chrisb is offline chrisb
Is it this?: Fostex FE126En Fullrange Speaker Driver (Transducer)
Originally Posted by planet10 View Post
FF125wk is closest.
dave
The two drivers cited 126/127 shouldn't really be considered interchangeable in the first place, so choice of replacement would depend on the the enclosure design. The FE126EN is still in production, it'd be the 127 that would find FF125WK as most likely "replacement" - noting that designs for the 127 might need some tweaking to tuning when using the new driver.
Old 2nd July 2014, 09:50 AM   #865
AmadeusMozart is offline AmadeusMozart  New Zealand
The narrow folded monopole... i've heard 2 versions of this, both are good. Inspired by the FE126 TL/BR hybrid, Chris implemented an interesting presentation (in getting finish right now, pics to follow)
Would the port need some lengthening from the specified 1.5" when using a flared duct as sold by Madisound? How much would be in the ballpark?
The Madisound Speaker Store
(makes it easier to get a good fit between cabinet and using otherwise just a piece of PVC pipe)
Thanks!
Old 2nd July 2014, 06:15 PM   #866
frugal-phile(tm)
planet10's Avatar
A flare shortens the effective length of the vent. I rarely ue a round vent.
dave
Old 2nd July 2014, 07:24 PM   #867
TerryO is offline TerryO  United States
TerryO's Avatar
Thanks!
To answer your question, yes it should be longer to compensate for the flair of the vent. When calculating the correct length for a flared vent, most add 1/3 (to 1/2) the length (depth) of the flair to calculate the overall length. Since I use a round-over bit to create the flair in the cabinet, I then add a PVC tube on the inside for a test measurement. If it's good, I mix epoxy and install the vent tube permanently.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 3rd July 2014, 12:59 AM   #868
A flare shortens the effective length of the vent. I rarely use a round vent.
dave
Dave / TerryO
thanks for the replies, much appreciated.
I am not particularly fond of round vents however the design is with a round vent and it is always best to keep the build as close as possible to the original tested version.
Old 1st August 2014, 03:04 AM   #869
Mounted on a wall, i'd go with the straight monopole... the folded one is to give an option that is more "normal" cosmetically
We asked that question too... Why would we build a Fonken if the diyA ref was even close, so we compared the diyA ref folded monopole we built for Chris' mom to a set of Fonken, We are still building Fonken. Ir has more finese and control... and certainly enuff to warrant the extra effort.
What amp do you have?
dave
I've just been looking at MJK's alignment tables. It appears that since the original monopole was designed more knowledge has become available and that it is better to mount the driver 0.349 * the length from one end rather than halfway.
The upshot of this is that with the folded monopole it is better to extend the divider down to the bottom and mount the driver approx 290 mm from the bottom keeping everything else the same. Models better in the worksheets too.
diyAudio Full Range Reference ProjectHide this!Advertise here!
Copyright ©1999-2017 diyAudio
