diyAudio Full Range Reference Project - Page 85 - diyAudio
Old 18th January 2009, 12:18 PM   #841
I have not really enjoyed my monopoles. They have a hollow sound to them, so I would suggest avoiding them. Everyone seems to rave about the Fonkens tho.
Old 18th January 2009, 05:17 PM   #842
frugal-phile(tm)
planet10's Avatar
Default Re: is it too late to ask ?
Originally posted by Bigun
question: still not sure if there is much difference (listening) between the monopole and folded monopole ? The straight monopole looks like a good option for wall mounting.
Mounted on a wall, i'd go with the straight monopole... the folded one is to give an option that is more "normal" cosmeticallt
question: the complexity of the fonken cabinet isn't a worry so the comments about it being better than the monopole caught my interest. It may be better, but is it marginal or more of a 'matter of personal taste' in terms of the sound ?
We asked that question too... Why would we build a Fonken if the diyA ref was even close, so we compared the diyA ref folded monopole we built for Chris' mom to a set of Fonken, We are still building Fonken. Ir has more finese and control... and certainly enuff to warrant the extra effort.
What amp do you have?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th January 2009, 05:18 PM   #843
frugal-phile(tm)
planet10's Avatar
Did you play with stuffing the port?
dave
Old 18th January 2009, 05:43 PM   #844
Originally posted by dublin78 I have not really enjoyed my monopoles. They have a hollow sound to them,
In addition to Dave's suggestion, did you try adusting the felt / lining / stuffing? Do they sound better up against a wall? Is there any way to pinpoin the frequenc(ies) affected, e.g. does vocal sound good but bass sound bad?
Old 18th January 2009, 09:06 PM   #845
Bigun is offline Bigun  Canada
Bigun's Avatar
Default Re: Re: is it too late to ask ?
dave
My current set up is simple stereo:
Bryston Integrated B60
YBA CD
Dynalab Tuner 101A
PMC FB1s
but the basement set up for HT is yet to materialize. If/when I DIY some speakers I may be enthused enough to DIY a Gainclone to drive them.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd March 2009, 01:30 AM   #846
Default TQWT for Fostex 127
please how to gain tuned sizes for
a tqwt design for 127e
japanes site shows an classic voight
groet, Bart
Old 4th November 2010, 03:13 AM   #847
r0b is offline r0b  Germany
So I am building this one, could someone please tell me if I can put the port on the back withoug messing it up. I know in normal br cabinets this is no problem, but then on this one, I don't really know what kind of cab it is
also, would it matter much, if the port is something like 36-37mm diameter, instead of 38? should I adjust the length?
Thanks for help!
Rob
Old 4th November 2010, 05:06 AM   #848
frugal-phile(tm)
planet10's Avatar
on the bottom (with suitable legs) or out the side is fine too.
dave
Old 4th November 2010, 08:43 PM   #849
preiter is offline preiter  United States
preiter's Avatar
IMO, the monopoles really need some baffle-step compensation.
Old 4th November 2010, 09:16 PM   #850
chris661's Avatar
Originally Posted by planet10 View Post
Here is a folded variation. Things are a bit tight around the driver, so we turn that into an advantage by making the partition the brace,
dave
Writing in with some listening impressions now the drivers have settled down.
The cabinet itself is very easy to build, and having the driver cutout on the fold makes stuffing adjustment very easy.
I use them in a bedroom, backed with a subwoofer. Crossover is ~80Hz, though the Fostexes themselves have output down to more like 60Hz in room. They're driven with an amp6-b from 41Hz, 12v supply at 5A. Plenty. Source is Apple Lossless from my iPod through a dock into a headphone splitter, then into each amplifier.
Built of 15mm MDF, yet vibrations aren't a problem until they're really pushed.
The cabinets were stuffed at the tapered end, with some comming around the driver (so it's level with the bottom of the cutout of the driver). This helped to stop internal reflections comming through the cone. Some bass is lost to adding the stuffing, but the improvements in the midrange were, in my opinion, worth this loss. Stuffing the ported end of the pipe meant some of the lower midrange was also lost, so I'd recommend stuffing the tapered end and around the driver, to avoid them sounding over-thin.
Anyway, the sound. The midrange is... Sublime. I struggle to describe it without using the usual words. Here goes... They're very natural and coherant - the FR magic is definitely there. They're revealing enough to lay bare any problems with recordings. Yet the huge amount of detail on offer doesn't detract from the performance (some speakers can end up over-analytical). The more I listen, the more I hear.
The treble is extended (certainly no need for a tweeter, even off axis). Metal things sound metallic (all the harmonics are present and correct); the sound of a pick hitting a guitar string is clear, and very very close to how it should sound (I play guitar, so it's easy to tell when the sound's right).
With such a small cabinet, of course bass won't be as extended as one might like, but I expected this. Still, as I said, they'll go to around 60Hz in room (more like 80Hz after stuffing). When pushed close to a wall, the bass becomes inflated and boomy. Not the sound I was after, so the combination of a crossover and stuffing has killed this off effectively.
The soundstage they create is truely amazing. During one particular violin solo (recorded at a medium distance through a stereo mic), you can hear the violinist move around (bending down and straightening up as they so often seem to do). With a different, 3-person vocal piece, they somehow manage to place one singer a foot right of the right speaker, another is sat on my desk, 2 feet to the left of the left speaker, and the third is just off-centre. I still find it amazing that they can position these voices so seperately, yet maintain the music as a whole. The entire experience is something to behold.
The only major downside to these is the limited maximum SPL. Despite being fully enabled, they still display stress when really pushed (full power from the little amp). However, for smaller-scale listening, they really are something else.
Chris
"If you underspecify some resistors they can add extra phlogiston to the music mix. This gives a much more dramatic effect than refulgence, however superb it may be. Phlogiston can move a listener in a way that ordinary music cannot." - DF96
Copyright 1999-2017 diyAudio
