Basic questions about Fostex drivers - Page 2 - diyAudio
Old 2nd December 2004, 03:21 AM   #11
Bill Fitzpatrick's Avatar
MJK:
Any chance of your redoing the images in the gallery? I wanted to see them but it became obvious that I am not going to live long enough for them to download.
Old 2nd December 2004, 04:01 AM   #12
Timn8ter, thank you for you suggestions.
Martin,
can you also please comment on my question 4 posts above since i think you worked closely with both drivers.
And I would like to say that your work is greatly appreciated. As a Junior EE student i learned a lot reading your website and pdf files. Thank you.
Old 2nd December 2004, 06:47 AM   #13
frugal-phile(tm)
planet10's Avatar
Originally posted by kepa1
the acr fe103s (which is a replica of the fostex)
A better description is an OEM FE103 with an extra magnet for more sensitivity & a bit lower Q. (ie built by Foster to ACRs design specs)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd December 2004, 05:16 PM   #14
MPM is offline MPM  United States
Default Re: Re: Re: Basic questions about Fostex drivers
Originally posted by OTMOPO3OK
Hello Timn8ter,
How would you compare 167E to 207E in ML TLs. say for 50% Music, 50% theater. Is Beaming from larger mains a problem for HT? Does beaming from 167E & 207E differ a lot. I understand that beaming for CC is actually very good.
Another thing: i see u did not recommend SuperTweeter for 167E but did for 207E. Do 167E sound more extended? How is the camparison of bass? If you were to do it all over again which driver would you chose?
As for me i was thinking 207E+ST MLTL and 167E MLTL(F3=50-60Hz) for center, 127MLTL(F3=60-70hz) for surround. Maybe u'll change my mind now.(i did not want to make surround smaller than 127E since i use it for DVD-Audio sometimes and i cross my sub as low as i can because i can hear where the bass is coming from)
Thank you, if you can tell me some other things i should note it would be good.
www.fostexspeakers.com will get you started with speakers and plans for a HT setup using the 206 or 207.
Some basic questions about Q wigginjs Multi-Way 8 20th October 2004 07:22 PM
basic questions for new guy jlh28 Everything Else 1 12th January 2004 12:49 AM
Basic LED Questions lgreen Parts 22 19th December 2003 06:26 PM
Basic Questions DarkMage Multi-Way 2 5th November 2003 02:51 PM
Basic Questions wnichol Solid State 4 16th November 2001 04:59 AM
Copyright 1999-2017 diyAudio
