Cain & Cain Abby Clone
Old 11th November 2004, 12:42 PM   #1
FrankDIY is offline FrankDIY  Canada
FrankDIY's Avatar
Default Cain & Cain Abby Clone
I call the project: Clabby (Clone Abby)
What do you think about these simulations?
http://www.diyaudio.com/forums/showt...765#post509765
I want a good compromise between cloning the look and cloning the sound. I am also planning to use solid wood to do the TL.
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein
FrankDIY's Audio Corner
Old 11th November 2004, 05:48 PM   #2
TC is offline TC  United States
The real Abby is not very expensive .
TC
Old 11th November 2004, 09:12 PM   #3
gl is offline gl  United States
Mr. Cain,
My complements to you on your loudspeakers. As you say they are not expensive. In fact considering the artistry, the time, and the quality materials put into them they represent a true bargain. I too am a life long woodworker and I appreciate what you have achieved.
That being said, this is after all, a DIY forum. You need to expect that the people here will generally choose to build rather than buy if possible. But I suspect that your comment was tongue in cheek.
Since you are here as a member I would like to ask you a couple of questions about your Abbey loudspeaker. You have included a turned. round plate behind the driver as a design element. Seigfried Linkwitz has some very interesting half space frequency response curves that he recorded using circular and square open baffle backing plates. These are on his web site and show significant comb filtering effects for the circular plates. I was wondering why you chose to use the circular plate as opposed to none at all. The port you use seems a bit small for the Fostex driver used and I was also wondering what the design rational was for the oval shape as opposed to square. Comments?
GL
Old 11th November 2004, 09:29 PM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Terry has made his choices, some of which contradict
conventional wisdom. From the little I know about how
he proceeds, his product contains a great deal of trial
and error and his decisions are based on listening more
than anything else. The result is an excellent product
which I'm happy to say I bought and use.
Old 11th November 2004, 09:54 PM   #5
reverber is offline reverber  Bulgaria
reverber's Avatar
Default Off Topic
FrankDIY,
A strange connection just closed in my mind...
You aren't by any chance moonlighting as a wine steward for a guy named Marcel, are you?
http://www.marcelgagne.com/
Cody
Old 11th November 2004, 11:59 PM   #6
FrankDIY's Avatar
Default Re: Off Topic
TC
I agree Mr Cain. The price asked for these speakers is very low. Unfortunatelly they are not available in Montreal and like most people here, we enjoy DIY and we love designing new projects or cloning great ideas. I did the same thing with many projects from Pass Labs. See that project a rewards for your unique and great quality product. Nobody on this forum is cloning bad product. I think this is a good sign
Seeing the pass few comments, I am very proud to see I have generated interest from two famous people
This pair of speaker will be presented in a contest that I am organizing in Montreal. Any comments on my design will be always appreciated.
Originally posted by reverber
FrankDIY,
Cody
No connection with that guy
Thanks for your comments!
Old 12th November 2004, 12:21 AM   #7
Thanks for the compliments gl. Yeah, I was attempting a veiled "funny".
The circular baffle projects the speaker out and away from the main baffle. With all the edges rounded with a long gradually decreasing radii, diffraction effects have been minimised. While I am sure some artifacts could be measured bouncing off the baffle I doubt it adds anything annoying that you could hear. It has been speculated that the baffle I make contributes to the large soundstage my spkr seems able to produce, again by elevating the driver off of the main cabinet a bit. Moreover I was interested in further reducing cabinet energy from reaching the driver by adding the (circular) mass. "Comb filtering" effects would be something that 2 drivers do, or two radiation points.. The diffraction effects of a single driver _can_ be seens as comb filtering though i see it as a stretch, implying first order cancellations. Not having read SL's paper you mention I am only guessing. The added mass and fluid surface adds benefits to the rest of the spectrum, if a slight cancellation/reinforcement results from a circular baffle it must be very slight.
Now if the circular baffle had sharp edges and was flush with the driver for it's circumference that could be easier to measure a step.
The port area was arrived at by building many a pipe. The design subscribes to alot of different theories about Voigts. I rely primariliy on actual physical modeling and measurements to arrive at these designs after the initial design work is complete. Choking off the pipe reduces ripple and pipe effect. The oval shape creates a wider sloping, fluid velocity value, lowering it's own self noise. May not even be audible vs a circular port.
TC
Old 12th November 2004, 12:34 AM   #8
FrankDIY's Avatar
This is very interesting. Based on these affirmations, I guess you did not use any baffle step compensation and then keep the efficency very high.
Old 12th November 2004, 03:48 PM   #9
Right.
Thanks again. and good on ya.
TC
Here's a link to a nice clone http://cls.audiogon.com/cgi-bin/cls....ull&1105182133
Old 12th November 2004, 05:38 PM   #10
Mr. Cain,
Thank you for your gracious and detailed reply. I appreciate you sharing your design experiences with us. I also appreciate you taking the time to answer my questions. I am experimenting with FR stuff at the moment and those particular questions about the Abbey have been in the back of my mind for a while.
Graeme
Cain & Cain Abby CloneHide this!Advertise here!
Cain&Cain Abby clone? (ML-TQWT??) FrankDIY Full Range 42 19th February 2012 11:33 AM
Cain & Cain I Bens---can I make them? May I? issabre Multi-Way 10 7th September 2007 11:33 AM
Terry Cain Harderror Full Range 1 29th January 2007 01:47 PM
We've Lost a Pioneer: Terry Cain ScottG Full Range 25 16th December 2006 07:28 PM
Cain & Cain & Class-T jives11 Full Range 19 21st July 2005 09:44 AM
