here's my new OB calculator :)
Old 10th November 2004, 02:40 AM   #1
hitsware is offline hitsware
Default here's my new OB calculator :)
http://home.comcast.net/~jhyamamoto/3ob3.xls
Old 10th November 2004, 05:46 AM   #2
Dave Jones is offline Dave Jones  United States
Default Re: here's my new OB calculator :)
Care to give us a hint as to what it does?
Davy Jones
Old 10th November 2004, 03:39 PM   #3
Default Re: Re: here's my new OB calculator :)
After determining Fc (the freqency of the first order HP filter imposed by the baffle) one can take a chosen driver and (with a sealed box calculator (put the driver in an infinite baffle)), add the filter and thus approximate the system response.................
Old 10th November 2004, 05:48 PM   #4
markp is offline markp  United States
A little more explaination would help. What are the columns and what is dia of?
If it sounds good... it is good!
Old 11th November 2004, 01:26 AM   #5
space/1=in a tree
space/2=on the ground
space/4=on the ground near a wall
space/8=on the ground near a corner
height and width are the dimensions of a rectangular baffle
diameter is the diameter of a circle with the same area as the rectangle.................
Old 11th November 2004, 04:03 PM   #6
Kittle is offline Kittle  United States
What measurement units are you using?
inches? feet? cm? meters?
Old 11th November 2004, 04:15 PM   #7
feet
Old 11th November 2004, 07:33 PM   #8
I think that there is more to it than that. The baffle can't just be converted to a round surface of uniform radius. The long axis will support lower freqs than the short axis etc....
Old 11th November 2004, 11:33 PM   #9
Intuitively I agree. However I have gleaned this approach from people who's knowledge I trust. Also it seems to be (empirically)
usable (within limits). A safer method would perhaps be to use the shortest dimension only (but perhaps too safe). This is in fact the same formula used to size the mouth of a horn. Obviously a mouth 1' x 9' is not going to act like a mouth 3' x 3', but perhaps if the ratio is kept reasonable all is well...........
Old 12th November 2004, 01:09 PM   #10
Gregm is offline Gregm  Europe
At the Fb calculation you have a constant "565". How do you get that?
I'm trying to convert the functions into metres/centimetres
here's my new OB calculator :)Hide this!Advertise here!
DRD calculator garbage Tubes / Valves 3 16th February 2016 07:01 AM
crossover calculator patriz Multi-Way 4 29th December 2011 12:11 PM
ac resistance calculator switchmodepower Power Supplies 1 24th May 2008 03:15 PM
inductor calculator bigpanda Solid State 12 9th April 2008 12:55 PM
BSC Calculator hongrn Multi-Way 5 10th December 2005 06:06 PM
Copyright ©1999-2017 diyAudio
