Well, since the standard Loudspeakers forum doens't give me a lot of response, I'll try to get some help here.
Well, I'm about to make a nice small speaker for the kitchen with a Vifa BGS 119/8, based on the Picolino tml speaker, for the german DIY magazine HobbyHifi (HH). The problem is, that this thing is just a bit to big So I have to make them smaller, thus a shorter TML. I know it will not get as deep down as the orriginal, but that is nog so important.Ik should look something like this: ![]() The box is about 20x25x16 cm The problem is, that I cannot het a decent simulation of this tml. I used the mathcad worksheets to simulate the original design, wich can be found here: http://www.audiocomponents.nl/speake...t-line_eng.htm TSP of the Vifa (according to HobbyHifi): Re: 5,5 Le: 0,20 mH Fs: 61 Hz Qms: 3,4 Qes: 0,62 Qts: 0,52 SD: 36 cm^2 VAS: 4 L Cms: 2,2 mm/N Mms: 3,1 g Rms: 0,35 kg/s BL: 3,3 N/A Xmax: 0,65 mm The problem is, I cannot reproduce the results that HobbyHifi has measured, no matter what I try The steady drop starts @ about 150 Hz with mathcad, while HH has a steep drop at about 60 Hz:![]() They use AJHorn to simulate, and the results are very close to the actual measurements: http://deepspace9.xs4all.nl/~christiaan/10bgs-7.jpg Sadly, I don't have AJHorn, so I'm hoping that someone can help me with some simulations, or maybe give me some other hints, so that the mathcad worksheets work... Please help me
#2 |
Hmm, even in a straight TL it sims down to ~60Hz.
How did you simulate the Picolino with the mathcad sheets? Did you put in the proper geometry with all the bends/area changes? If so, you could send me the file. It´s a bit of a contradiction to scale down a TL but you should get nice results with your size restrictions. One fold should fit nicely.
jens |
#3 |
Yes, sure, you're cheating with a TQWT
I want a real TML |
#4 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
well, in this case, there realy is no difference with BR, so IMHO not worth a try (I would just make a BR then).
I would like to make a tapperd tml, like in the picture. The point is, mathcad cannot reproduce the measurements HH made (and also what AJHorn simulated) |
#6 | ||
frugal-phile(tm)
dave
#7 |
Well, as i see it, it the parameters were not wrong, but that is why I need your help...
Well, I tried again, and now, I do get something similar to AJHorn, so I'm on the right way |
#8 | |
would you mind posting your results? Cheers
jens |
#9 |
#10 |
Did you put in the proper geometry or simulating with a 100cm line and constant cross-section-area?
jens |
| Downscaling Zen v.9 for use as headamp | kenev | Pass Labs | 34 | 12th April 2010 01:06 PM |
| Downscaling ZV9? | panos29 | Pass Labs | 5 | 27th April 2006 12:03 PM |
| Downscaling resistor values? | Mick_F | Chip Amps | 5 | 2nd November 2005 10:53 AM |
| Pico Lino downscaling | 4real | Multi-Way | 4 | 7th November 2004 10:32 AM |
| Page generated in 0.10977 seconds (80.89% PHP - 19.11% MySQL) with 11 queries |
