Picolino downscaling - Page 2 - diyAudio
Old 8th November 2004, 05:05 PM   #11
4real is offline 4real  Netherlands
Originally posted by joensd
Did you put in the proper geometry or simulating with a 100cm line and constant cross-section-area?
I simulated with a *SD from 3,6 tot 0,38 (as in the picture) . An constatnt cross section line is not very good, and won't fit the box
I might do a more detailed sections simulation, but I think this one will do
Old 8th November 2004, 05:32 PM   #12
joensd is offline joensd  Germany
and I even have room for my amp and FM receiver
now, where are you going?
wasn´t that supposed to be a christmas present for your parents?
you can fold the line and still keep the CSA constant.
jens
Old 8th November 2004, 05:40 PM   #13
Yes it is , active wireless speaker, but I think I'll put some real terminal on it, too, for a real amp . The thing I'm going to use now is 6 W TDA chipamp, not the best, but it will do...
Sure I could, but it will not fit in the box. The resulting curve does not look very good either!
Old 11th November 2004, 03:13 PM   #14
kyote is offline kyote  Germany
Have you build this thing alreay?
How does it sound?
And would you mind to put a detailed plan (with angles and width) in here?
It looks real interesting.
And perhaps some Pictures?
Old 11th November 2004, 04:05 PM   #15
I hope te get the units this weekeind, and I might even get started with building it
Detailed plan with angles? Well, I'm not shure If there is realy going to be an actual detailed plan, but I might try to make something up tonight...
If it is realy going to sound as well as the simulations say, is just a matter of building and listening
It will be my first TML project, so I'm very excited to get started with it
Pictures will be there when I have them :P
Old 11th November 2004, 10:57 PM   #16
Just for the fans (and for my own ease), some drawings
I had to find a fairly decent pice of free CAD software to help me. I found QCAD, and it works very nice
At first a small png of the desgin:
Click the image to open in full size. (don't expect to see any measurements on that picture )
But here some PDF's
A2 format: http://deepspace9.xs4all.nl/~christiaan/picolina.pdf
A4 format: http://deepspace9.xs4all.nl/~christiaan/picolina_a4.pdf
All measurements in mm's
The lines are very thin, so your printer might not print very well.. I'll have to look into that.
I recommend that you don't build the thing befor I have no good results. You never now how bad I'm at designing stuff
I'll keep you posted!
Old 12th November 2004, 08:09 AM   #17
Ok. Im staying tuned in excitment of your results.
I hope my english is not too bad.
Old 12th November 2004, 08:14 AM   #18
No, I don't think so. I hope mine is not bad either . You can write in German to me, but I don't thinks that the majority of the diyaudio readers would understand that
Old 12th November 2004, 08:53 AM   #19
Yeah, that's what I hink, too.
But it's a bit weird to write to e.g. Joens in english.
Lucky that there are german DIY forums.
Old 13th November 2004, 03:01 PM   #20
earsandeyes's Avatar
Default Workaround QCad
4Real,
How did you wordk around the 10 minute timelimit on the free software?
E&E
Downscaling Zen v.9 for use as headamp kenev Pass Labs 34 12th April 2010 01:06 PM
Downscaling ZV9? panos29 Pass Labs 5 27th April 2006 12:03 PM
Downscaling resistor values? Mick_F Chip Amps 5 2nd November 2005 10:53 AM
Pico Lino downscaling 4real Multi-Way 4 7th November 2004 10:32 AM
Copyright ©1999-2017 diyAudio
