Old 5th November 2004, 04:06 PM   #1
morbo is offline morbo  Canada
Default 16 ohm drivers?
I know that 16 ohm speakers are meant to be wired together to form an 8ohm load, for instance in an MTM. But, it is safe/advisable to run a 16 ohm driver like this one:
http://www.creativesound.ca/details.php?model=WR125ST
From a regular amplifier or reciever?
Old 5th November 2004, 05:26 PM   #2
MEXXX is offline MEXXX  United States
Send a message via AIM to MEXXX Send a message via MSN to MEXXX Send a message via Yahoo to MEXXX
You could run a 160 ohm driver on a "regular" amp and it wouldnt hurt it.
The higher the impedance, the lower the "draw" on the amp. So yes, you can. But remember, you will only get about half the power into a 16 ohm speaker as you would an 8 ohm.
Old 5th November 2004, 06:17 PM   #3
Timn8ter's Avatar
Many owners of tube amps prefer a 16 ohm load.
Old 5th November 2004, 09:38 PM   #4
thanks guys, looks like I will be ordering these
Old 5th November 2004, 10:26 PM   #5
frugal-phile(tm)
planet10's Avatar
And half the distorion (in general)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th November 2004, 11:28 PM   #6
Power shouldnt be a problem, this speaker will get the (claimed) 100wpc into 8 ohms from my mass market reciever. Your distrortion statement intrigues me though - my reciever (Pionerr 811s) has a pretty weak amp section, and does not 'officially support' a 4 ohm load, does this mean it will have an easier time driving a 16ohm speaker than an 8ohm speaker? Because with my big floorstanding 8ohm towers, it is not very dynamic, I ended up using the preamp outs for the front channels so I could use an outboard amp with some balls (1970's Yamaha reciever), and it would be nice to avoid the need for a separate amp for this speaker (center channel).
Old 6th November 2004, 12:53 AM   #7
Timn8ter's Avatar
Originally posted by planet10
And half the distortion (in general)
dave
That's been my experience too.
(need a new keyboard Dave?)
Old 6th November 2004, 04:19 AM   #8
frugal-phile(tm)
planet10's Avatar
No, just never learned to type (the f key is right beside the d key)... took Grade 11 Math instead of Grade 10 typing.
dave
Old 11th November 2004, 09:39 PM   #9
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Maybe you lose less than the theoretical 3dB with 16 Ohm series using small tube amps, especially SET? I would expect so with a high output impedance amp. Did you ever measure SPL when parallel (4 Ohm) double drivers vs series (16 Ohm) when fed off an 8 Ohm tap? Speakers are governed by voltage, so maybe less of a loss than expected? Do you subjectively feel not so much of an spl loss when using push push 16 Ohm vs push push 4 Ohm with tube amps? Planet 10?
Old 14th November 2004, 11:09 AM   #10
Salas's Avatar
Timn8ter? Planet10? voice in a desert here....
JBL comp drivers, Dayton Reference Sub drivers for auction NO RESERVE pkpickard Swap Meet 1 21st January 2009 03:19 AM
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
21" Bass Drivers and Beyma Compression Drivers Magnetar Swap Meet 0 19th November 2006 02:42 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 09:11 PM
FS: horn subs, drivers, 'regular' subwoofer drivers John Sheerin Swap Meet 0 1st August 2004 11:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
