what makes a loudspeaker "full range"?
Just so I post in the right place, is there a definition?
Thanks, Dave |
Would generally be a single driver / array of identical drivers reproducing the entire audio band and usually devoid of a crossover network.
Examples of full-range driver loudspeakers are Lowther, Fostex, Diatone etc. These loudspeakers try to cover the major frequency span of human voice and common musical instruments without a crossover to another driver. Wide-range drivers, those that try to cover most of the frequency span and only rely on another driver at the extremes (i.e. a subwoofer or a supertweeter) can also fit this category. Horn loudspeakers are also considered full-range. Horns can extend full-range drivers, and some horn systems attempt wide-range performance with few drivers.
Okay,
So if I build a speaker system based on one driver--even though it's not designed to cover frequencies below 100Hz--that's a full-range loudspeaker, and my completed project will be posted here. Eh? Dave |
Yep, many "full range" projects fall in that category, for example John Krutke's W3-871S projects.
The definition I have used when moving posts to this forum is that the loudspeaker should have been designed not to need a tweeter and should have its fundamental mechanical resonance <100Hz.
How about Fs 111Hz?:) I'm building a TL with the TB 881s. Should I post it here or in the general forum?
Thanks, Dave |
| All times are GMT. The time now is 02:52 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
