I have coated my FE206E in the hope of reducing the peak centered at 2.7khz.
Well it made no difference to that peak, but it reduced the minor peak centered at 900 hz which did improved the sound quiet a bit. So my FE206E still have a small peak at 550hz and the large one at 2.7khz. Does anyone have an idea how to reduce the peak at 2.7khz? |
#2 |
The one and only
My own measurements show only a small peak at 2.7 KHz,
not much taller than surrounding ones. RLC networks with the R, L and C in parallel and the result in series with the speaker is a popular way of reducing peaks in Fostex speakers. You can see my data in the current source amp/speaker article on www.firstwatt.com which has a response and impedance curve. Modeling up a network for it would not be too difficult. check out http://www.quarter-wave.com/General/BSC_Variable.pdf |
#3 |
i still think the most worthwhile tweak i made to the smaller cousin of the 206e (the 166e) was adding a "socket" phase plug a la Steve Deckert. It subtly (subjectively) reduces peaking but improves off axis response and makes the driver more listenable
See pic (the powdery stuff is dried up damar)
"Any fool can know. The point is to understand" - Albert Einstein |
#4 |
yes the socket phase plug does help, but doesn't remove the problem totaly.
| Cd frequency responce ? | woody | Everything Else | 16 | 17th January 2008 03:22 AM |
| BiB - responce ripple reduction ? | Empee | Full Range | 48 | 10th December 2007 05:35 PM |
| 100k freqency responce | kz0071985 | Class D | 9 | 2nd September 2007 05:26 AM |
| Responce - spelling rant | joe carrow | Everything Else | 73 | 26th May 2007 01:57 PM |
| freq. responce help on mini amp | ThSpeakerDude88 | Chip Amps | 49 | 21st July 2005 04:02 PM |
