Building ML TL with Fostex FE 167 E - Page 3 - diyAudio
Old 7th October 2004, 06:55 PM   #21
weidok is offline weidok  Netherlands
weidok's Avatar
Originally posted by Bob Brines
Yes, double the top and line it with cement board, tile, whatever. You will be amazed at the difference this makes in the amout of vibration -- and sound -- coming from a thin top panel.
Bob
Thanks Bog,
i double te top ..
i just made the drawings used 7/8 " (22 mm) MDF
Instead of using a pvc tube i am using wooden rings
to eleminate vabrations of a tube..
Must i do something about the vibrations from the frame of Fostex
i read other users of fullrange speakers did it to?
Greetings Weidok
Hee Leeuwarden welcome.. worldwide...
There is NoBox like NoBox
Old 7th October 2004, 08:24 PM   #22
frugal-phile(tm)
planet10's Avatar
I've not used a driver yet that doesn't benefit from some judicial use of DuctSeal (the Phy-HP being the only driver i've touched that didn't actually have anywhere to put it). I won't install a stamped frame driver without some duct-seal treatment.
Morse probably had some interesting comments about the series of small tweaks he did to his.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th October 2004, 10:34 PM   #23
Morse is offline Morse  United States
Hi Dave!
Funny you should mention the rope caulk tweak now - I just applied it to my first "post workshop move" speakers a couple of days back. As expected, it cleaned up the midrange nicely, as well as removing a bit of an 'edge' to the upper midrange (gotta be a basket resonance at work there).
The "felt on the back of the magnet" tweak had a more subtle, but still useful impact, so it's a 'must do' on any speaker with a ferrite magnet IMHO. I've run out of felt padding momentarily though, so the "felt on the insides of the basket legs" tweak will wait until next week.
Interestingly, one thing happened in this project that proved a complete surprise (though it shouldn't have): the improvised mounting for the binding posts proved a wholly inadequate solution (all I had handy at the time of construction was some perfboard and soft PVC type plastic to place as a gasket). Replacing those with proper 1/4" thick plywood mounts that I affixed with polyurethane glue yielded a substantial improvement in bass potential from these tiny little 5.6L RS40-1197 BR/folded TL hybrids. Midrange clarity also apparently suffered from the resonances that these improvised mounts introduced, since there was an increase in image depth accompanying this change. I'd expected a small improvement in performance, but the results of this experience make me wonder about the potentially deleterious effect of the "weak wall" that many cheap mounting cups for speaker connectors constitute. On "no holds barred" projects, I shall continue my practice of using binding posts with long enough shafts to be used without any mounting plate assembly at all - just a hole for each post through the cabinet.
One last thought in the "cheap but critical tweaks" department is that on office speakers some thought must be given to the acoustic properties of the desk or table they're to be sat upon. The RS40-1197's have enough bass now that they can really make the top of that desk resonate (unpleasantly) and muddy up the sound. This has (mostly) been cured by using 3/4" thick rubber feet (3 per cab) on the bottoms of the speakers to act as a decoupler.
Hope I didn't put anyone to sleep! :-) Oh well, time to get back to grading papers....
All the best,
Morse
Old 10th October 2004, 10:13 AM   #24
weidok's Avatar
Default Tweaks Fostex
Tanks Morse
So i wille use the rope caulk tweak , it will clean up the midrange nicely.
And mounting binding posts on the gasket ?
Do you have any pictures of it so i understand it better?
Old 10th October 2004, 05:26 PM   #25
frugal-phile(tm)
planet10's Avatar
Default Re: Tweaks Fostex
If you can find ductseal you will be further ahead... rope caulk tends to harden over time and the benefits of the tweak as well.
dave
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 06:00 PM
building a sub box shovelhead 93 Car Audio 3 22nd February 2009 11:19 PM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 01:35 PM
Building Fostex 126E Help needed ddmddm Full Range 1 16th December 2005 05:44 AM
Copyright 1999-2017 diyAudio
