Building ML TL with Fostex FE 167 E - Page 2 - diyAudio
Old 5th October 2004, 09:04 PM   #11
weidok is offline weidok  Netherlands
weidok's Avatar
Ok so i just ordered the speakers "Fostex"FE 167 E
form germany..
I'll use the demensions from BOb's FT 1600 mk II
the port will be round 3 " and about 41/4" long
Instead of using a pvc tube i am thinking using wooden rings
to eleminate vabrations of a tube
There is NoBox like NoBox
Old 5th October 2004, 10:10 PM   #12
Bob Brines's Avatar
form germany..
Remember that those are outside dimensions and assume 3/4" material. There is also a 1/4" cement board lining. The actual pipe dimensions are 40x8.5x8.5.
Bob
Old 6th October 2004, 07:30 PM   #13
weidok's Avatar
Bob,
Cement board can you explain that i really don't know what that is ??
Must i double the top ...
And are other users with the Fostex Fe 167 E or not ???
Please let me (us) know about and reply on this post ?
Old 6th October 2004, 07:44 PM   #14
Timn8ter's Avatar
Cement board here in the US is a ceramic based material 1/4" thick that is used in (typically) home construction to put tile on, such as bathrooms, kitchens, etc.. I've used it in building TLs and highly recommend it to reduce cabinet vibrations. Other materials can be substituted if it is the same thickness, or you account for the thickness in your internal volume. Granite tile, ceramic tile or other types of floor tile can be used. A good construction adhesive can be used to attach it to the inside of the cabinet panels.
Old 6th October 2004, 11:41 PM   #15
Bob Brines's Avatar
Bob,
Timn8ter has it right. The brand I use is "Hardi-Backer", though this information is probably of little use outside North Amaerica. I used to recommend ceramic tiles, but the Hardi-Backer is much easier to cut to size.
Yes, double the top and line it with cement board, tile, whatever. You will be amazed at the difference this makes in the amout of vibration -- and sound -- coming from a thin top panel.
Bob
Old 7th October 2004, 12:48 AM   #16
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Cement board seems very brittle, can you cut it with normal table saw etc. What about glue, is PVA ok for this stuff?
Old 7th October 2004, 02:06 AM   #17
Sounds like it could be "beton-multiplex". It is available in a "bouwmarkt". It is a lot more expensive than normal multiplex.
Old 7th October 2004, 04:26 AM   #18
Bob Brines's Avatar
Get a diamond abrasive saw blade for your table saw. Gets dust everywhere, but cuts nicely.
I use Liquid Nails panel adhesive.
Bob
Old 7th October 2004, 04:32 AM   #19
Thanks Bob
Diamond abrasive saw, ouch that sounds spendy
Might try find a diamond jigsaw blade
cheers arthur
Old 7th October 2004, 12:09 PM   #20
peterr is offline peterr  Netherlands
peterr's Avatar
It is certainly not "beton-multiplex". It is more like fermacell which is used as an alternative to waterproof "gipsplaat". You can buy fermacell at the professional building material shops like "Bouwmaat" not sure about diy shops.
Keep an open mind. It helps.
Peter
fostex 208ez and fostex ft17 h good kombo? almightybozo Full Range 1 24th September 2010 07:00 PM
building a sub box shovelhead 93 Car Audio 3 23rd February 2009 12:19 AM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 08:21 PM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 02:35 PM
Building Fostex 126E Help needed ddmddm Full Range 1 16th December 2005 06:44 AM
Copyright 1999-2017 diyAudio
