tangband 3" full range w/ wood phase plug?
Old 30th April 2005, 05:38 AM   #21
AnthonyPT is offline AnthonyPT  Australia
Send a message via ICQ to AnthonyPT
Hi
Doing the Gallo thing is where I started.
I had a pair purchased in San Fran when on
a visit to the USA. This was in 2000.
While I have not been able to match the driver
decoupling in the origninal Gallo balls I feel
that a 150mm sphere with the 517S1 or SA can
do a decent job even in an acrylic sphere that
was designed for lighting not audio. Besides has
anyone ever really seen a full measurement of a Gallo
ball? An OZ review did take them apart and found
sort of straws as stuffing! Then had a hard
time getting the unit back together. My acrylics
I call Calipsos are fine as long as you do not
drop them. Gallos dent if you drop them. Papier mache
might be the go. Its tough and when lacquered looks great.
My dentist loves the Gallos I bartered
for some bridge work !
Pictures show papier Mache lacquered unit and Acrylic
cored sphere.
AnthonyPT
Old 30th April 2005, 08:04 AM   #22
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by AnthonyPT
and found sort of straws as stuffing!
I've seen straws used for aperiodic loading but not as stuffing... i can see how it might work thou.
Papier mache
An easiy to DIY approach, and something that is quite versatile -- quite complex shapes could be made. An artist friend does a lot of papier mache with good results. One of my favorites is the attached lawyer. We actually discussed building speakers this way, but then he moved...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th April 2005, 08:05 AM   #23
frugal-phile(tm)
planet10's Avatar
Pictures show papier Mache lacquered unit and Acrylic cored sphere.
Have you larger pictures?
dave
Old 30th April 2005, 09:31 AM   #24
Here is the Papier Mache
Old 30th April 2005, 09:35 AM   #25
Here are the acrylics with the
threads for light fitting use removed
ready to fit any 3" round driver
Old 30th April 2005, 09:40 AM   #26
frugal-phile(tm)
planet10's Avatar
Some major care to get that morroe finish!!! impressive
dave
Old 30th April 2005, 09:47 AM   #27
Here is the 205mm ceramic stoneware
unit with a Axon 4 inch. IMHO very nice !
I have slightly smaller spheres that
will take 3" drivers but have not had the
time to cut the six holes for each sphere.
Tiring and tedious but worth it if you can do it.
Line it wiith a weighted core and rock wool.
AnthonyPT
Old 30th April 2005, 09:58 AM   #28
As to the Lacquerware papier mache
work, Cambodia, Vietnam and Laos
do this sort of thing so well and at
low cost. Could do the same sort of
magic on a Paulownia wood sphere with the
right local contacts.
AnthonyPT
Old 4th May 2005, 08:11 AM   #29
motherone is offline motherone  United States
Anthony, all I can say is those are damn cool! I haven't seen something this spiffy in a long time. Thank's for the inspiration! I'm going to have to look into building some of these guys for sure, now!
Could you provide any more insight into how you're mounting the drivers? Any tricks to it, or is it pretty straight forward?
Old 4th May 2005, 04:02 PM   #30
Hi motherone,
Thanks for the encouragement!
To mount drivers I find I generally use a sort of
blue tack or equivalent. I use a Jaycar
speaker sealant cat.CF-2762 it is grey and
then on the ceramic spheres it makes a very nice
gasket to support and seal the drivers. As you can see
I have used nylon nuts and bolts to perhaps help
decouple the driver. The TBW3-517 drivers I have used
steel nuts but mounted them with the heads also
facing outwards. I can then add short offsets (spacers) to add
a grill to deter fingers if necessary. The black support as seen
in the red lacquer picture is a plumbing ring but with rubber
edging which can be added to keep the driver positioned.
Wall mounting could be done with Altronics bracket Cat.H8012.
I have been playing with the Ikea speakers stands for a while.
See pictures. Putting weighted cores in the sphere really makes
life easier and overcomes a lot of issues. The 517s drivers seem to be
ok in a 150mm sphere but I will be trying a 200mm also.
The 517 door nob phase plugs, which are really what this thread
is about, sometimes needs to be reglued but have not had
anymore trouble with them since. Maybe a Dammar coating might
enhance things??
Check out these sites:
http://www.jaycar.com.au
http://www.altronics.com.au
For other ideas (small subs) check
http://www.historystones.com/noname4.html
tangband 3" full range w/ wood phase plug?Hide this!Advertise here!
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 06:17 PM
Phase Plugs For Single Full Range Drivers thetubeguy1954 Full Range 15 23rd June 2008 11:09 AM
1.5" - 2" full range weather resistant speaker? eRiCdWoNg Multi-Way 0 1st May 2008 08:12 PM
Aura 3"...phase plug? Stocker Full Range 56 16th May 2005 08:00 AM
TangBand full range drivers Fred Sanford Multi-Way 3 27th March 2002 04:02 PM
