The Locust I
GM said:
nothing ventured, nothing gained. ;)
GM
I did put an equation into the worksheet to re-calculate Qts, but I got a different number, so I'll check my formula.
[Added a few minutes later] Actually, I just copied the formula from a worksheet on Martin's web page. The worksheet is for the Fostex fe206e. (Of course I changed the original Q to the one for the fe107e.)
Here is the formula:
Qed' := Qed*(Re)*(Re-Rs)**-1
Is that right?
I'm probably already reaching the limit of what those little drivers can do, even in a small room. For a given SPL, cone excursion quadruples every octave, right? And the xmax on those is tiny. Still, I'll play around some more.
Dave
"Nothing vented nothing gained."
I think I have the Qes figured right now, and I put in the numbers exactly as you said. Here's the function, assuming a total added resistance of 5 Ohms:
Correct.
Yeah, and I don't know how much excursion it has before either popping out of the gap and hanging, or bottoming out. For sure I wouldn't drive it past 1/8" until you find out what Xsus/Xmech is.
Hmm, don't know what you're doing, but you're not getting the right response. Notice that the IB response hasn't flattened out so it's not plotting the higher Qts response, ergo the higher Q vented response.
GM
Fair enough. Not having heard this driver, I was just curious. Yeah, they impress me too. I've been designing tower speakers (now ML-TL) since the late '60s, but no formula I could ever find would accurately predict vent length, and not having the math skills to wade through all the gas law formulas I never could come up with any calc or even rule-of-thumb to figure it. And of course stuffing was trial n' error.
GM
Rather than doing a stretch Locust 34 inches tall, it would make more sense to do an even taller floor-standing speaker using the fe127e. That one has a lower Fs, higher Qts, and bigger xmax.
GM, would you care to try your magic on that one?
I'll give you something to shoot at:
At a glance, I doubt I can improve on it without going large flared. I did an extended max flat alignment awhile back for someone that a false bottom filled with kitty litter/whatever can be added to get the driver up high enough, but AFAIK it wasn't built:
L = 39.46"
SO/SL = 43.785in^2
driver down 14"
1.875" dia x 0.5" long vent near/at the bottom
BTW, does the view/refresh or ctl-r work for you?
GM
The phase plugs arrived and I installed them. I did one side first and listened A/B. The plugs made a very distinct improvement. Not only was the treble distortion almost completely gone, but even the bass seemed to be better defined. I did the other side, then listened to them a long time last night. I think these little things may be sounding about as good as the Ariels now.
Sorry for that OT-question that just comes to my mind.
GM, I "re-simulated" a lot of designs you´ve given (thanks a heap)
to hopefully learn something from them.
It´s going well so far but what still puzzles me is the driver position.
You always seem to have the ratio around 0.35xx.
I know (at least I think I know) that one should damp out resonances like the 3rd harmonic.
But especially there where you seem to set the driver the overall resonances seem higher to me.
I always get good results at around 0.45 +-0.02.
In the recent FE-127E design for example at 0.45.
Isn´t it advantageous to get a TL with overall minimized resonances
or am I completely on the wrong path?
Best regards
Jens
BTW: THIS one is on the way (the 42"). If it´s not gonna work out I´ll come over.;)
