Fostex Enclosure - Page 2 - diyAudio
Old 15th June 2004, 03:54 AM   #11
Kofi Annan's Avatar
I happen to know a great place that carries it in Atlanta, called Atlanta Wood Products
Always with the great advice. You know I'll be there tomorrow.
I would just use the 5/8" mdf and you should almost be able to fully follow the plan with some unit conversions and sanity checks.
Will do.
I finally bought a house last week, and it is about 4 miles from this place, and I move in on July 15th.
Congratulations! Homeowership is great. Glad to hear that you'll be out of apartment life. Hope you keep making great stuff and I wish you and the Mrs. lots of luck.
By the way, let me know if you need help moving. Its the least I can do. Well, the least I can do is abosolutely nothing, but this would be one better than that.
I'll start the project anew tomorrow and I'll post something when I cut my forking arms off. At least, I'll dictate to the wife and she'll post.
Kofi
Old 15th June 2004, 08:34 AM   #12
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Originally posted by Kofi Annan
That's what I camp up with too. Thank God.
32mmD, 44mm H, 8mm W.
32mmD - 2, 21, 22, 10, 4, 8, 12, 13
44mm H - 14, 16, 17, 18, 19, 20, 11, 3, 7, 6, 5
8mm W - 1, 15.
...still looking for the holy grail.
Old 15th June 2004, 01:16 PM   #13
Josephjcole's Avatar
I also am stuck working in inches and have been forced to convert some of the fostex recomended enclousures to use 3/4" wood. I always just increased the outside demensions slightly, then you should be able to get everything pretty close. Just try to keep everything up right on as far as you can. A small difference at the mouth of the horn is no big deal, while the same difference could cause problems at the throat. But maybe you've already got 5/8" by now, in which case my advice is irrelevant
oh well
Joe
Old 15th June 2004, 03:04 PM   #14
Kofi Annan's Avatar
My brain is about to explode.
The reason I'm making the smaller horn with the 103E is that I have some 206Es on order and I wanted to make the Fostex-recommended horns for those. In other words, my experiment with the 103Es was a dry run for the 206Es and I can see now that this is going to get really ugly.
Anyone got a design for the 206E drivers in Imperial / English measurements? If so, I can stop this nonsense and build Tim's voigt pipes and use another design for the 206Es when I receive them.
YYYYYEEEEEEAAAAAAARRRRRGGGGGHHHHHHH!!!!!!!!!
Kofi
Old 15th June 2004, 05:04 PM   #15
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Kofi
Try not to explode, but if you look at the 206e fostex enclosure, they are using 21mm thick wood for that...
A great alternative, which I have seen recommended on another forum, would be to build the 208ez enclosure:
http://www.madisound.com/208ez_enclrev.pdf
It uses 18mm thick wood, which corresponds close enough to 3/4", and is said to be a much better design and will work with the 206e.
I think building the 103e enclosure with 5/8" would be good practice first though.
Another design to look at:
http://home.hetnet.nl/~geenius/Solo206.html
Brian
Old 15th June 2004, 06:45 PM   #16
Kofi Annan's Avatar
OK.... OK.... Kofi's feeling better now. I called AWP and they have 5/8" MDF. I'll be running by there tomorrow to get some.
With the 103E design, I'll be out .875mm for each board if I use 5/8", but I'm thinking that won't amount to much in the end. I should be able, as you have described, fully follow the plan. If I compromise on the dimensions of the internal spaces, I'm thinking I'll be out about a millimeter or so per gap. That's not the end of the world, right?
Also, I should still be able to use my 3/4" MDF for the external portion of the cabinet. This would seriously cut down on the amount of wasted wood product.
That sounds like a plan.
Yeah! This is the one I'll build for the 206E then. Again, I'll be off about 1mm per gap, but hopefully that will still work out OK.
Thanks again!
Kofi
Old 15th June 2004, 07:13 PM   #17
Greg B is offline Greg B  United States
Personally, I would just build the thing from 5/8" particle board and stop worrying. It's not a big box. Beaverboard will work fine and is readily availabe in 5/8". Plywood is common in 5/8" as well, but it needs to be void free. BTW, ply is typically undersized, and nominal 5/8" likely *will* be 15 mm.
You can always sheath the thing with hardwood or plywood if the box sings too much.
GB
Old 16th June 2004, 05:41 AM   #18
Also, consider the size of 1mm. It isnt a whole lot, little more than a pencil line. 5/8 should work fine for 15mm without any reconfiguation. If you can build a box sized down to the exact mm then you are a better carpenter than I or have a lot more time on your hands
Old 16th June 2004, 01:44 PM   #19
Kofi Annan's Avatar
Been measuring my stock with an electron microscope. 1mm is HUGE on the atomic scale. Now if I can just keep the dust mites and giant specks of pollen off the wood...
Thanks for all the advice. On my way to Atlanta Wood Products today.
Kofi
Old 16th June 2004, 01:47 PM   #20
BrianGT's Avatar
Kofi
Good luck. I am curious to see how the backloaded horns will sound.
Brian
best enclosure for fostex 208 sigma? dondiba Full Range 71 6th December 2013 10:31 PM
Horn Enclosure for Fostex 206 Puffin Full Range 71 15th March 2009 09:25 PM
Fostex 108 Small Enclosure Ronmeister Full Range 39 23rd February 2009 01:55 AM
FOSTEX FE126 in Fostex BR Enclosure nafunga Full Range 3 29th July 2008 07:21 PM
Jordan JXr 6HD and Fostex DBR enclosure neil_kaye Full Range 5 11th January 2006 11:07 PM
Copyright 1999-2017 diyAudio
