Radio Shack 40-1197 (aka FE103)
Old 10th May 2004, 08:09 PM   #11
CrisTUFR is offline CrisTUFR  Canada
Originally posted by Timn8ter
If you're looking for very high SPLs then you should consider another driver, however, if you're looking to drive them at normal listening levels they can handle it ok. I use TBs in my HT with a 100W per channel SS receiver and haven't blown one up yet. If you put two drivers per enclosure you should be fine.
I think I will definitely have to go for the two-to-a-cabinet approach so that I can squeeze a bit more range out of them. Also, it's not like the drivers will break the bank to muck around with anyway.
From there, if I'm able to build decent-sounding speakers on my own for the office, my wife will allow me to build all the speakers for our surround sound setup at home (since she'd prefer to just drop the cash on ready-made "safe" speakers).
I can sympathize with her attitude right now, since most people just don't think you can reproduce the sound of a "good" (read: expensive) speaker on your own. Also, I've only just recently built things on my own (gainclone) that actually work "as advertised".
I've got a bunch of birch veneer plywood, a fully-functional wood shop, and a small amount of cash to spend on building a set to prove 'em all wrong.
Old 10th May 2004, 08:35 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Power rating for the 1197 is rated at 4W for what it is worth. So 2 is going to be 8W. I regularily use mine with 100W and have never smoked any. Power rating is really an overrated & misunderstood specification. I usually just ignore it.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2004, 09:15 PM   #13
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
True, true. For an in depth discusson on Watts = Quality see
Watts = Quality?
Old 10th May 2004, 10:18 PM   #14
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
Originally posted by planet10
The wooden pipes with the FE103As now house tweaked 1197s
built. One day i had the red pipes in the car (just painted mdf),
Eficeincy i stimate in about 91 db, a 4.5 W EL84 SEP starts running out of steam at high levels (in my large room) but is superb for normal listing levels. Recent indications are that series wiring may be better sonically than parallel.
dave
Thanks for the info, but I still have a few more questions...
Sticking with the pipes (wooden and red), do you have drawing with measurements for them? Do you use a filter or anything on the 40-1197 drivers? How are they connected, series or parallell and are they in phase?
The prototype drawing you posted has several similarities for the AllegraAudio BV-1 (minus the taper). What is the benefit of placing the drivers back to back? Also, do you hook them up in phase? Is the horizontal location of the driver critical? I would prefer to have it a sitting ear level.
Is more information regarding the 40-1197 not available (i.e. freq. responce curves, Re .....)
Cheers
Old 10th May 2004, 10:29 PM   #15
Timn8ter's Avatar
Link to some 40-1197 parameters
http://f18.parsimony.net/forum31999/messages/19030.htm
There have been a few different production runs so YMMV.
Old 10th May 2004, 10:42 PM   #16
frugal-phile(tm)
planet10's Avatar
BD-Pipes plans
http://pmillett.addr.com/tqwp.htm
Drivers connected in parallel or series & in phase (i am starting to get some feedback that, particularily with tube amps, 16 ohms makes a biggere difference than i would have guessed -- i have yet to experiment).
No filters, just "mechanical" tweaks. Ductseal, puzzlecoat, woolfelt, dustcapectomy, phase plugs... the ductseal is a required tweak.
The ptototype is probably similar to Tim's pipes because, he says, he has been inpired by my preaching
Back-to-back makes them CRT friendly and gives optimal push-push coupling (inproved downward dynamic range, reduced transmission of energy to the box). In phase. Driver distance from the end of the pipes is critical. Ajust height by changing the length of the "legs (everything below the port is purly to get the driver up to the right height).
dave
Old 11th May 2004, 02:14 AM   #17
gmilitano's Avatar
BD-Pipes plans
On that link, it shows a filter, but it is labelled FE103, should I be using that with the 1197? I would be interested in adding a tweeter to this design. Would this be an improvement on the high end? Going along on with your original post, I would be looking at a first order high pass of about 10 kHz. Furthermore, the 40-1030 does not seem to be available anymore would the 10CM (4") WOOFER 40-1022 be an appropriate replacement?
I like this design too. Do I need to experiment with insultation? I believe Tim insulated the upper portion of his. If I was to add a tweeter, does it need to be isolated from the inside of the box?
Obviously! I dunno what I was thinking?
Ok, with regards to the numbers, the link Tim gave showed an efficiency of about 90.5 db. By using two drivers, what would be the net efficency? I imagine I would need to know this to pick an appropriate tweeter.
I think it is clear that the low end of the 1197 is about 80Hz. How much is this value lowered by the enclosure or by the back to back setup. What I am asking is what would be the estimated frequency responce and would a subwoofer be required.
GM.
Old 11th May 2004, 04:27 AM   #18
frugal-phile(tm)
planet10's Avatar
There is an optional filter, i like the speaker better without it.
The 1197 isn't as extended as the 103/103A/108. The speaker sounds OK without, but you really notice it is missing if you remove it.
Here is a tweeter i've found to work particularily well.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3096034842
I've only used the same speaker as in the front, i think the 1022 is a bit down efficieny-wise -- i'd just use 2 1197s per box.
No... the designated amount of stuffing just fit into the box.
Tim's uses 2 drivers 90.5-91 dB is about right.
Listen to them, if you want subteranean bass you will need woofers (modern day drivers designed for sub use, usually don't have enuff top end to blend well).
dave
Old 11th May 2004, 10:24 PM   #19
gmilitano's Avatar
Thanks for the info Dave.
With regards to the stuffing on the proto-1197-ml-tl, there are no details regarding stuffing.
If the individual drivers are about 90.5 dB, does using two drivers increase the efficiency?
You also mentioned that the height of the enclosure is critical. How is this height determined? Is it based on experimentation, or can software be used to model the enclosure. I have been playing with speaker workshop .. is this approprite or do I need something different?
Thanks,
GM.
Old 11th May 2004, 10:44 PM   #20
Timn8ter's Avatar
The old blue box 1197s were of 90db efficiency, the newer ones are less. Two drivers in parallel are usually calculated as having a +6db increase.
Radio Shack 40-1197 (aka FE103)Hide this!Advertise here!
Radio Shack FE103/40-1197 drivers FS transaluminum Swap Meet 1 7th May 2009 09:31 PM
NIB Radio shack 40-1197 in pairs noisenyc Swap Meet 6 5th June 2006 08:28 PM
radio shack 40-1197's noisenyc Full Range 0 30th May 2006 03:15 PM
Radio Shack 40-1197, looking for DizRotus Full Range 1 10th July 2005 08:46 PM
FS: Radio Shack RS 40-1197 Dick West Swap Meet 4 12th April 2005 05:24 PM
Copyright ©1999-2017 diyAudio
