Old 5th May 2004, 07:31 PM   #1
Default Fe107e offset driver TL
Hey guys, would you be kind enough to criticize a proposed design? Check out the thread below.
The design is in message #8. By the way, I used 4.5 for BL, and 16*pi cm^2 for the effective cone area.
Calculate BL
Davy Jones
Old 6th May 2004, 12:21 AM   #2
Bob Brines's Avatar
Looking at the plot, assuming that the input parameters are correct, something is very wrong here. My gut feeling without running sims is that the pipe is way to big for the driver. It is also way over stuffed, as can be seen by the gradual fall-off at the low end. But, it needs the stuffing to smooth out the higher harmonics, and it's not doing that well.
I don't like small drivers in pipes. There is too much temptation to make the driver go too low. The FE107E is a mid-tweet, not a mid-bass. It deserves to be used as such in a horn or OB, or even a sealed box, but not in a pipe.
Just my opinion. Sorry.
Old 6th May 2004, 02:20 AM   #3
Yep. It's junk. Everyone please disregard. :-(
Davy Jones
driver offset - time alignment vs diffraction deiksac Multi-Way 4 28th August 2006 04:42 PM
Alpha Transmission line - can the driver be offset? adamt Multi-Way 3 26th June 2006 11:36 AM
Offset driver - Fostex 206E in Open Baffle ? Steve M Multi-Way 3 28th June 2004 02:52 PM
MJK Offset Driver simulation with PL-18 Help JC Fardo Multi-Way 7 20th June 2004 06:28 PM
Page generated in 0.07728 seconds (70.42% PHP - 29.58% MySQL) with 10 queries
