Is this a good idea?
Old 23rd June 2018, 02:34 AM   #31
RXV is offline RXV  Philippines
Moreover; For purely movie watching,
What would be the better driver used for surround/Atmos duties? (In terms of extended HF, DDR, details/clarity). Considering that these speakers will be set to SMALL and HPF cut-off at 80-100hz:
Markaudio Pluvia 7 (metal)
Markaudio Alpair 6 (metal)
Markaudio Alpair 5 (metal)
All three drivers are very near in terms of price.
note: I have an Alpair 7, but it is out of the question since it is in a different price point
Old 23rd June 2018, 02:53 AM   #32
chrisb is offline chrisb
Andy if I may -and at the risk of puffery - while Dave & Scott have between them almost innumerable designs, and I’ve built at least scores of them for proof of concept and bespoke sales, I also have well over a decade of attempting the art of compromise in a multi-channel surround HT system using enclosures from their catalogs. Even though he has a much better acoustic space than either of mine, Dave is still only running a 2.1 system - sometimes even absent the .1 section IINM?
So my point would be that, to reiterate what GM and others have probably stated here and elsewhere, if implementing a discrete front row 3, the center is the most significant channel in terms of resolution - although not necessarily requiring the same full bandwidth as the L&R mains if the system is also used for music only, and in a direct/bypass mode - i.e. a situation in which it would almost certainly be mute. If you’re fortunate enough to not be constrained on size/ footprint across the front row, I’d definitely suggest the same drivers and enclosures for all three, and as any modern surround AVR worthy of the designation would provide bass management control to tailor the surround effects channels - up to, what 9 these days? - to filter whatever LF content might exist to the mono-summed LFE channel, the surround enclosures can be as small as practical for the chosen drivers.
I’m pretty sure I already posted a link to the “Micro-tower home theatre appendix” plans, which while dated now in terms of the CHR70 intended, show the flexibility available with small sealed designs.
RXV - in short, if budget permits, I’d go for the Pluvias.
It is of course way too easy to overthink all of this and get stuck in analysis paralysis.
As always, caveat emptor, YMMV, free advice is worth what you paid for.
like my mind, this space intentionally blank
Old 23rd June 2018, 05:16 AM   #33
@chrisb
Thanks for the reply. The Alpairs 5 ($53) and Alpair 6 ($56) are actually a little more expensive than the Pluvia 7 ($45)
Old 23rd June 2018, 06:06 AM   #34
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Just to mix things up...
The Pluvia 7 has a big edge in bass and volume levels it can attain. Technically both Alpairs the would have the greatest DDR, A6.2m to get low enuff to get as low as you want. But my personal pick would be A6.2p.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd June 2018, 06:20 AM   #35
Andy Gamble is offline Andy Gamble  United States
Chris, it goes up to at least 15 channels these days: center, left, right, side surrounds, rear surrounds, front wides, and front, middle and rear heights. I think I've heard of a rear center, too. With Atmos and DTSx you can theoretically add speakers of dubious benefit ad infinitum. I'm sticking with seven or nine.
I certainly intend to use the same driver and enclosure for the front three channels. If anything I have more space for the center than for the l&r, so I can do three reasonably sized towers. The tall skinny MLTLs are physically a good size and shape for the surrounds so I don't see a down side to using them there. I'll use the same driver for all channels.
So for the front three, Pensil, Derwent or Windmere? I like the idea of the deeper bass extension of the Windmere, but I'm not sure what I'd be giving up (other than size). I have no idea how an MLTL would compare to a BVR.
Old 23rd June 2018, 07:13 AM   #36
Upon further thought, it would probably be a bit daft to try to get a 4" full range to extend below 50hz when I have a subwoofer, so let's count the Windermere out. What should I expect the difference to be between the Pensil MLTL and the Derwent BVR when placed up against a wall? I've never heard either type of enclosure, and I've seen both described as improvements on bass reflex enclosures, but I haven't found any clues regarding how they compare to each other.
Old 24th June 2018, 12:09 AM   #37
Andy - daft never stopped many a DIYer.
It’s been so long since I listened to a BVR other than the Vampyr - if that qualifies, so it’d be supposition on my part to opine as to the likely differences. FWIW, while I’ve flirted with other designs - that sound great but don’t suit the room decor as well- I’ve been pretty happy with the Pensil design for both A7, and now the A10.3 in my home theatre system for well over 5 years now. If you’ve got the floor space, that’d be my suggestion. But of course, I’m at the twilight of my building “career”
Old 24th June 2018, 12:17 AM   #38
frugal-phile(tm)
planet10's Avatar
I’m just guessing but i’d suapect the TL goes lower. Althou not the lowest possible tuning.
Note: Vampir-V is an ML-Voigt with horn loaded vents.
dave
Is this a good idea?Hide this!Advertise here!
Is it a good idea to buy this kit? nullbyte Chip Amps 7 24th March 2012 09:41 PM
Is this a good idea? 3-way W-DC-W Rojoh Multi-Way 0 26th October 2009 09:24 PM
Is this a good idea? AC439 Multi-Way 0 30th December 2008 07:48 PM
Seems a good Diy idea !! sivan_and Everything Else 1 12th November 2006 07:44 AM
