Best Full-Range 4" with Passive Radiators?
Old 15th March 2018, 08:56 AM   #21
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Size is important, when this is an issue excursion can make up for it, a bit, so I've been told
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 15th March 2018, 09:01 AM   #22
Aleixdet is offline Aleixdet  Spain
Im impressed, thank you everyone!
One more thing and regarding the amp, which one would you recommend for the Alpair 6 or the RS100?
ALPAIR 6 RMS is 15W MAX is 30W
RS100 RMS is 30W MAX is 60W
I suppose that a mono AMP with 60W would work well?
Old 15th March 2018, 11:54 AM   #23
afa is offline afa  Australia
Using a single Dayton ND91-8 in a 1.5-1.8 litre box with two opposed 3.5" peerless passive radiators (to help stop vibrations and the speaker jumping around) will get you down to mid 60s with no eq required.
Old 16th March 2018, 03:37 PM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Power ratings are near meaningless. There are no standards by which to measure them and 2 brands can have quite different numbers and yet be the same. Best to ignore them.
We recommend a minimum of 10w for the Alpair 6… it has an arrestor built in the will audiably tell you when to turn it down… more power is usually better than too little but there are lots of other factors that are important.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th March 2018, 04:39 PM   #25
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
What Dave said. Whatever driver you go for, forget the RMS values. All they really tell you is the point at which the voice coil will fry. They'll have reached their mechanical excursion limits in any box you're likely to use at a fraction of that, unless you electrically cut output < tuning.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 12th July 2018, 07:40 PM   #26
bknop is offline bknop  United States
bknop's Avatar
The dynavox ly401f is also worth a look, it has a low fs of 53.5 hz and a qts of 26. I chose to tune a 0.138 cu. ft. (3.9 l) box low, to about 40 hz. It works very well with a little eq on the bass in a smaller room, to be flat. The low response limit is around 34hz.
Best Full-Range 4&quot; with Passive Radiators?Hide this!Advertise here!
Passive way to maximize Dayton ND91 3.5" full range bass? CZ Eddie Full Range 11 10th May 2016 03:02 PM
Looking for: 15" passive radiators hatrack71 Swap Meet 1 30th December 2014 05:17 PM
12" passive radiators JVC Wavebourn Vendor's Bazaar 5 21st June 2010 08:22 PM
WTB~2 12" Passive Radiators Relax Swap Meet 0 24th April 2006 02:29 AM
WTB: 10" Peerless Passive Radiators !!!! DaHos Swap Meet 0 25th February 2005 12:36 PM
