Some questions for my first 4 inch
Old 7th May 2018, 09:56 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
This particular driver has a relatively high Q. It is not suited to a reflex box. It wants to be in an open or infinite baffle ideally. If you want to do a box, it should be as large as you can live with. I’d recommend a minimum of 5 litres. At that volume the Q is ~1 (ie a bit underdamped), with F6 80 Hz, F10 just above 60 Hz.
You could also make it aperiodic which wouldn’t hurt, bringing the box Q down.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th May 2018, 10:03 AM   #22
gkh is offline gkh  Austria
gkh's Avatar
Unfortunately, I can't delete this oh-so-rotten post with the sim anymore. Could someone please do this for me?
Old 7th May 2018, 01:04 PM   #23
vha is offline vha  Europe
vha's Avatar
Thank you maybe you can help me better:
The internal dimensions of the box I am already preparing are: 31x14x20 cm. The net volume of 8,68 liters. Ca you check if should the diameter of the vent be smaller (2,5cm) and length be about 3 cm?
What would be the frequencies?
What would be the diameter and the length of the port?
Old 7th May 2018, 01:18 PM   #24
gkh's Avatar
If you mean me - no, I don't help anymore. Sorry.
Old 7th May 2018, 03:14 PM   #25
vha's Avatar
Originally Posted by planet10 View Post
This particular driver has a relatively high Q. It is not suited to a reflex box. It wants to be in an open or infinite baffle ideally. If you want to do a box, it should be as large as you can live with. Iíd recommend a minimum of 5 litres. At that volume the Q is ~1 (ie a bit underdamped), with F6 80 Hz, F10 just above 60 Hz.
You could also make it aperiodic which wouldnít hurt, bringing the box Q down.
dave
Yes thank you
I am preparing enclosures of 8.6 liters for one driver.
I have not decided yet if vented or sealed.
I would need to understand for the diameter of the port and the length.
I would prefer a flat line and not peak in low frequencies.
If sealed then would need some damping material but if vented I am not sure..?
I did some testing before ordering the final wood and plywood to hear the sound with 2 larger enclosures. One enclosure with 2 drivers in parallel and one with one driver as on the pictures below. The sound was more bass when vented at the bottom front of the box and with just little dumping material behind the driver.
Old 7th May 2018, 06:38 PM   #26
frugal-phile(tm)
planet10's Avatar
That is an OK volume. It should not be ported. Leave it sealed.
dave
Old 8th May 2018, 11:39 AM   #27
vha's Avatar
Yes This was my first idea. Why would you think better keep it sealed?
Old 8th May 2018, 06:17 PM   #28
frugal-phile(tm)
planet10's Avatar
The free air Qt is already higher than ideal, sealed or aperiodic is indicated, putting it into a BR just makes things worse.
dave
Old 9th May 2018, 07:53 AM   #29
vha's Avatar
Thank you Dave
Old 18th May 2018, 08:28 AM   #30
vha's Avatar
What if I put 3 of those Faital pro 4FE35 in a 20 liters box?
Some questions for my first 4 inchHide this!Advertise here!
18 inch BR questions and driver preferences. treukauf Subwoofers 32 2nd September 2016 05:19 PM
2 inch Peerless vs 2 inch HiVi Research richie00boy Multi-Way 18 5th December 2007 07:31 PM
Passive Radiator system with 2x10 inch and 1x15 inch Lach O'Sullivan Multi-Way 3 13th September 2003 03:29 PM
