Old 9th April 2004, 01:45 PM   #1
kepa1 is offline kepa1  France
Default advice on a woofer to match fostex fe 103s
hi all,
and thanx to those who brought this excellent site.
well, i 've just built bookshelves using fe103s and they clearly need some extra bass.
the offer for woofer is quite impressive and maybe someone can help me out?!
my design is to add two woofers cut up to at least at 200 / 300 hz, in small sealed boxes (25/30 liters).
ideally, the woofer should be made of paper, with a high efficiency (90db +).
any clue guys?
Old 12th April 2004, 03:43 PM   #2
UP!
in other words, i'm looking for a very fast woofer that would go along with the fostex fe 103 sygma, really fast too!
Old 12th April 2004, 06:31 PM   #3
If your taking one woofer per side they need to be very efficient,
much more than the Fostex due to baffle step correction, given
your box size and the FE103e cost i'd suggest this :
http://www.partsexpress.com/pe/showd...number=290-083
Crossed over at the BSC frequency series first order.
EDIT : just noted they will be in different boxes with different
BS frequencies, perhaps parallel Linkwitz / Riley 2nd order
would be better ?
sreten.
Old 13th April 2004, 06:36 AM   #4
frugal-phile(tm)
planet10's Avatar
Are you going to bi-amp or try to get a passive XO to work?
If you go passive, you'll need to get real close to the right sensitivity because you probably don't want to pad the FE103.
If you go active, it leaves you a lot more choices.
I've a couple projects on the go with similar goals. I'm using older vintage drivers (8s or 10s) that were designed to be very extended.
If you can go with a couple extended range woofers per side you can load them push-push, and gain some sensitivity. I'm working right now on a design for some ApexJr 8" to be used with FE103A. It will be active -- these drivers are not very sensitive, but they are quite extended on the top.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
How do I match a woofer and tweeter? chasingame Multi-Way 3 6th August 2009 07:35 PM
Woofer adivce to match my tweeters IG81 Multi-Way 19 16th April 2009 05:37 PM
Woofer/Tweeter match Mjr7531 Multi-Way 5 5th April 2005 11:47 PM
Should woofer material match driver mat. BROKEN THIRDS Multi-Way 0 19th April 2004 04:43 PM
Should Woofer material match drivers BROKEN THIRDS Introductions 2 19th April 2004 01:54 PM
Copyright ©1999-2013 diyAudio
