Metronome build question???
Old 18th February 2018, 06:00 PM   #1
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
Default Metronome build question???
I am going to build a pair of Metronome cabinets for a friend. He'll be using the Audio Nirvana 10" driver. At what angle do I need to cut the sides of the top and bottom pieces, as well as the bottom of the cabinet (edge of the MDF) that sets on the ground?
Thanks,
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 18th February 2018, 06:06 PM   #2
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
I would cut at an angle 45.
Old 18th February 2018, 07:44 PM   #3
Tom V is offline Tom V  United States
I used my router table to rabbet the edges of all the panels, with the rabbet on the front panels fractionally wider than deep. After assembly (alignment helped by the rabbet) I then used a flush trim bit to clean up the edges.
Rabbet - Wikipedia
Old 18th February 2018, 07:46 PM   #4
As far as the top and bottom pieces, don't sweat the math. Just use the cut out front and side panels to set the angle for the table saw.
-Tom-
Old 18th February 2018, 07:50 PM   #5
For the base sitting on the ground, I tacked on a straight piece front and back to act as a guide, and then used a hand saw to cut off the bottom of the panels. This not only gave me the proper angle for the flat base, but also fixed any minor mis-alignments of the panels.
Old 18th February 2018, 07:56 PM   #6
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
Mike,
I have built quite a few Mets. The top & bottom pieces I get by measuring the angles on a scaled drawing. Cut them on a table saw set to the measured angles, but make them slightly over sized. I measure the size after the sides are glued to the baffle. Then I try fitting the top & bottom pieces to judge how much they need to be cut down to make a perfect fit, and to check the angles. Back to the table saw & trim them--slowly & carefully. I put a straight edge (thick metal ruler) across the side edges to see if the part is too wide for the back to fit properly. Any small amount too large I take off with a sanding block. I wish I had pictures to show, as it's easier to see how it works than to use words!
A day without music is like a day without food.
Old 18th February 2018, 08:03 PM   #7
Oh, and remember to cut the hole for the port tube BEFORE you glue the bottom in!
Old 18th February 2018, 08:05 PM   #8
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
MDF?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th February 2018, 11:24 PM   #9
Originally Posted by planet10 View Post
MDF?
dave
That was my friend's choice.
Old 19th February 2018, 12:10 AM   #10
phivates is offline phivates  United States
We're sorry
Metronome build question???Hide this!Advertise here!
Metronome build inquiry/ for Dayton Audio PS 220 Delbert Full Range 8 11th October 2015 03:28 AM
Small Room - Metronome - First Build JOHNAKI Full Range 18 26th June 2013 06:06 PM
another metronome question evanc Full Range 0 17th May 2011 03:44 PM
Prebuild tips for Metronome F167 Build AdamThorne Full Range 25 14th May 2008 09:32 PM
help!, need dimension for metronome build with TB W3-871S gychang Full Range 2 2nd December 2006 10:24 PM
