Peerless 3" computer speakers
Old 23rd February 2018, 08:18 AM   #31
champ222 is offline champ222  England
Great, thanks again. Will have a play today if i get time.
I did think 20W was a bit excessive, but as you say, they are cheap enough.
one more thing, you said "So if you try this and find the audio is a bit distorted a polypropylene in parallel of 3.3 - 10uF should help to pass the high frequencies. It will shift the bass a little but so little that it won't matter." would 3.3 or 10uF be more effective? or should i go somewhere in the middle?
Old 23rd February 2018, 10:17 AM   #32
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
10uF will be better, basically the larger you go the better the bypass will be. I stopped at 10uF as if you go larger than that in polyproplene they get very expensive.
Eventually it would also get large enough to affect the bass response significantly so you would need to reduce the size of the non polar electrolytic.
Andy
Old 23rd February 2018, 12:14 PM   #33
ok, thanks Andy
Old 23rd February 2018, 12:33 PM   #34
suhail123 is offline suhail123
Wink Peerless 3" computer speakers
Originally Posted by mikejennens View Post
Part way down the page are the results of Bass Box Pro with this driver. According to this, you might be surprised at the bass you can get.
Peerless by Tymphany 830987 3" Full Range Woofer
Mike
amazing thanks
saim malik
Peerless 3" computer speakersHide this!Advertise here!
Bass from a 3" driver with small box for computer speakers deandob Full Range 42 20th August 2012 09:08 PM
8" or 10" sub driver to go with computer speakers, music only, sealed cabinet. doors666 Subwoofers 9 25th November 2010 03:17 PM
3" computer speakers wicked1 Multi-Way 33 19th July 2010 09:12 PM
"Thumpremover" for computer speakers MammaMumin Chip Amps 9 27th December 2008 12:49 AM
Turning 10" peerless sub's into 3-way speakers? newboy Subwoofers 2 2nd May 2008 10:15 AM
