Peerless 3" computer speakers
Old 13th February 2018, 06:30 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
This driver has a high Q so you will get a bump in the bass even in an infinite baffle. The way to deal with that is usually an OB, where the leakage around the sides counters the rise (but the large size needed is impractical) or an aperiodic enclosure where an attempt is made to damp the peak.
Certainly a vented box is not a good idea.
Start with the largest sealed box you can live with. You might like the bump, but if you find the underdamped response not to your liking you can start drilling some holes in the back and damp those holes. This is very much a cut and try process so go slowly. You can use GMs clik test or measure for maximally flat impedance curve. Or just listen.
EQ is the other option, but i dont think as effectove as an acoustic fix.
This is a picture of one of the most well developed aperiodic speakers i know of. It gives some indication of the approach.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th February 2018, 09:53 PM   #12
Bjohannesen is offline Bjohannesen  Denmark
This driver will do very well in TABAQ. The folded version could be used as desktop speaker. Put it upside down with the opening downwards using some small feets on the enclosure.
Bjørn
http://www.kvart-bolge.com/
Old 15th February 2018, 12:28 PM   #13
champ222 is offline champ222  England
So i did some listening last night. i found some cardboard boxes (i know) that were similar in size to what i was looking at, a bit deeper though and due to the fact that its cardboard, the volume is bigger, about 3.8 litres ish.
They sounded pretty nice. not a lot of low end, as expected, but plenty of detail, and nice to listen to at low levels. worth persisting with.
The TABAQ looks like a floor standing design? unless there is another version? I'll do some research...
thanks
Old 15th February 2018, 12:31 PM   #14
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
Here is the folded version of the TABAQ
http://www.coolcat.dk/bjoern/TABAQ%2...et%20build.pdf
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 15th February 2018, 02:37 PM   #15
Its still a bit bigger than i'm looking for though, can i make it smaller?
Old 15th February 2018, 02:48 PM   #16
I don't believe it can be changed and still be optimum.
Old 15th February 2018, 03:10 PM   #17
i thought that may be the case. I'm going to try some various port lengths over the next few days.
Old 15th February 2018, 03:21 PM   #18
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
I did a simulation of the speaker in a 0.1Cft (2.8L) box with baffle step and diffraction. If you are close to a wall then it will fill the bass back in a bit. The baffles step more than compensates for the peak in the response in a 2.8L box. but it means the mid will be elevated reference the bass by approx. 5dB.
I will see if I can work out a simple correction filter.
Old 15th February 2018, 03:48 PM   #19
gfiandy's Avatar
This is a fully compensated design if place close to a wall the bass might be a bit much.
I have taken the box and baffle simulation merged them with the responses from the data sheet to provide simulated in box measurements and then applied a correction network made up of a bass shelf with a resistive component to level if out followed by a capacitive resistive element to lift the response back up after the baffle diffraction hump.
Below are the uncorrected merged data, the filtered corrected response and the filter components.
Old 16th February 2018, 10:31 PM   #20
Wow, thanks for all your efforts guys, I'll see if I can find those components and try it out. This is for a sealed 2.8 litre enclosure Yeah?
Thanks again.
Peerless 3" computer speakersHide this!Advertise here!
Bass from a 3" driver with small box for computer speakers deandob Full Range 42 20th August 2012 09:08 PM
8" or 10" sub driver to go with computer speakers, music only, sealed cabinet. doors666 Subwoofers 9 25th November 2010 03:17 PM
3" computer speakers wicked1 Multi-Way 33 19th July 2010 09:12 PM
"Thumpremover" for computer speakers MammaMumin Chip Amps 9 27th December 2008 12:49 AM
Turning 10" peerless sub's into 3-way speakers? newboy Subwoofers 2 2nd May 2008 10:15 AM
Resources saved on this page: MySQL 66.67% / PHP 41.34%
