CSS FR125S 'fullranger' anything comparable?
Old 8th February 2018, 06:02 PM   #21
audioaficionado is offline audioaficionado  United States
audioaficionado's Avatar
So far: Looking like 5" and up will require too large of Vb or Vc for desktop use. Vas is only considered as a rough indicator of the enclosure size. Xmax ~ one indicator of low frequency capabilities.
dia"[xmax mm, Vas L, Eff dB]
Fostex FF85WK 3"[0.35mm, 1.036L, 86.5dB]
Fostex FF105WK 4"[1.7mm, 4.848L, 88dB]
Fostex FF125K 4.5"[1.65mm, 7.265L, 89dB]
Markaudio CHR70.3 4"[4mm, 5.17L, 85.4dB]
Markaudio Alpair 5.2 3"[3mm, 1.324L, 84.6dB]
Markaudio Alpair 6P.2 3.5"[4mm, 3.6L, 86dB]
Markaudio Pluvia 7 4"[4mm, 5.543L, 86dB]
Markaudio Alpair 10P 6"[7mm, 30L, 89.6dB]
Tang Band W5-2143 5"[2.5mm, 19L, 90dB]
Tang Band W6-2144 6-1/2"[3mm, 34L, 89dB]
Tang Band W5-1611SAF 5"[3mm, 11.5L, 90dB]
Tang Band W3-1878 3"[4.2mm, 3L, 88dB]
Tang Band W4-1879 4"[5mm, 9L, 87dB]
Tang Band W4-1052SD 4"[3.4mm, 7.6L, 87dB]
Tang Band W4-1320SJ 4"[3mm, 5.9L, 89dB]
~Steve
Old 8th February 2018, 06:22 PM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
We have used these drivers and put them into (as small as is the smallest we have put them in):
Originally Posted by audioaficionado View Post
Fostex FF85WK
Optimum 2.5 litre, as small as 2 litre
Fostex FF105WK
5 litre, 3.6 litre
Fostex FF125WK
Markaudio CHR70.3
9 litre, 5 litre
2.5 litre
Markaudio Alpair 6.2P
5 litre, 2.5 litre
Markaudio Pluvia 7
11-13 litre, 5 litre
17 litre, 7litre
Tang Band
Not a lot of experience… mostly loaded into horns.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th February 2018, 09:45 PM   #23
Thanx Dave,
I can load them into BassBox6 and play with Vb and Fb or Closed Vc values. Smaller drivers will tend to beam less HF. Not sure how much whizzer cones, phase plugs, cone contours affect HF dispersion.
~Steve
Old 8th February 2018, 09:55 PM   #24
frugal-phile(tm)
planet10's Avatar
If one can get away without whizzers or phase plugs then one is ahead AFAIC.
Be careful with the modelling… it is way easier to come up with an ugly alignment than a good one. Sealed is much more tolerant but almost all of these need the extra output from a vent to do bass.
dave
Old 9th February 2018, 02:52 AM   #25
When modeling there are a lot of things to consider past the frequency response graph. Test boxes, FR and Z measurements, etc.
~Steve
Old 11th February 2018, 11:47 PM   #26
Fostex FF105WK 4"[1.7mm, 4.848L, 88dB]$54.70
Fostex FF125K 4.5"[1.65mm, 7.265L, 89dB]$62.70
Fostex FX120 5"[2mm, 8.21L, 89dB]$144.30
Markaudio CHR-70-Gold Champagne Cone 4"[5mm, 5,17L, 85.4dB]$36.00
Markaudio CHP-70-P Gen2 Natural Paper 4"[4mm, 4.7L, 86.5dB]$36.00
Markaudio Pluvia 7 4"[4mm, 5.543L, 86dB]$45.00
Markaudio Alpair 5.2 3"[3mm, 1.324L, 84.6dB]$53.00
Markaudio Alpair-6M Gold 3.5"[5mm, 4.8L, 5dB]$56.00
Markaudio Alpair-7 Gold Cone 4"[4mm, 4.58L, 85dB]$85.00
Tang Band W5-2143 5"[2.5mm, 19L, 90dB]$51.90
Tang Band W4-1320SJ 4"[3mm, 5.9L, 89dB]$65.80
Tang Band W3-1878 3"[4.2mm, 3L, 88dB]$84.84
Tang Band W4-1879 4"[5mm, 9L, 87dB]$147.50
~Steve
Old 13th February 2018, 12:07 AM   #27
dia"[xmax mm, Vas L, Fs, Eff dB]<$60
Fostex FF105WK 4"[1.7mm, 4.848L, 75Hz, 88dB]$54.70
Markaudio CHR-70-Gold Champagne Cone 4"[5mm, 5,17L, 65Hz, 85.4dB]$36.00
Markaudio CHP-70-P Gen2 Natural Paper 4"[4mm, 4.7L, 72Hz, 86.5dB]$36.00
Markaudio Pluvia 7 4"[4mm, 5.543L, 68Hz, 86dB]$45.00
Markaudio Alpair 5.2 3"[3mm, 1.324L, 101Hz, 84.6dB]$53.00
Markaudio Alpair-6M Gold 3.5"[5mm, 4.8L, 63Hz, 5dB]$56.00
Tang Band W5-2143 5"[2.5mm, 19L, 55Hz, 90dB]$51.90
Peerless TC9FD18-08, 3.5"[2,6mm, 1.24L, 125Hz, 84.5dB]$13 (are you kidding?)
I want low level detail foremost, bass is important also, but planning on a modest near field sub to augment. Don't want listening fatigue in the mids,highs.
~Steve
Old 13th February 2018, 12:20 AM   #28
frugal-phile(tm)
planet10's Avatar
A6.2 or A5.2 then. A6 will get you a bit more bottom.
dave
Old 13th February 2018, 05:06 AM   #29
Throwing my wallet into the wind, what are the winners from the more expensive list above?
~Steve
Old 13th February 2018, 05:41 AM   #30
frugal-phile(tm)
planet10's Avatar
EnABLed Alpair 7.3.
dave
PS: some will call me biased
CSS FR125S 'fullranger' anything comparable?Hide this!Advertise here!
Amp comparable to the Marantz PM-68 FuzzyBastard Solid State 7 8th January 2017 10:07 PM
what's comparable to the ppi art amps? havieri23 Car Audio 2 22nd April 2008 05:07 PM
Something comparable to a Quad 405? PoorSound Solid State 0 23rd January 2006 03:19 PM
