CSS FR125S 'fullranger' anything comparable?
Old 7th February 2018, 12:55 AM   #11
audioaficionado is offline audioaficionado  United States
audioaficionado's Avatar
Near is within a few feet or so. Either on desk or stands. Not expecting reference levels. Just intimate elegance.
~Steve
Old 7th February 2018, 02:31 AM   #12
Markaudio has some really nice FR drivers at very reasonable prices. TangBand has some nice drivers, but 3x$ of MA. Fostex has lower XMAX higher prices. Probably good for low level nearfield.
~Steve
Old 7th February 2018, 01:07 PM   #13
IG81 is offline IG81  Canada
IG81's Avatar
Perhaps planet10 or others can chime in as they certainly have more experience than I with Fostex drivers, but the ones I've heard behave gracefully enough when pushed beyond Xmax. Sure, they won't do club-level bass-heavy techno in any kind of sustained manner, but they handle dynamically rich music quite well IMO. I listen daily to a pair of FF125K (see my avatar) with an almost non-existant Xmax of 0.15mm and they have no issue playing at satisfyingly loud levels near-field.
Old 7th February 2018, 01:11 PM   #14
rb132333 is offline rb132333  United States
I am talking about these two drivers for example:
Tang Band W5-2143 5" Paper Cone Full Range Driver 8 Ohm - $51.90
Tang Band W6-2144 6-1/2" Paper Cone Full Range Driver 8 Ohm - $81.40
Are the MK drivers cheaper? I always thought they were more expensive.
Old 7th February 2018, 02:38 PM   #15
I looked at lots of FR drivers on Parts Express and Madisound. Some use whizzer cones and phase plugs or cone profiles to give better HF dispersion. It's hard to choose. I want a compact sized enclosure so I need a driver that works in smaller Vb or Vc.
~Steve
Old 7th February 2018, 03:49 PM   #16
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
How small?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th February 2018, 04:15 PM   #17
I had 4 of the MK CHBW-70s which had a plastic frame and did not seem sturdy to me. I ended up using them in my friend's synergy for his mancave.
I had 4 of the VWR126X drivers in an OB and I found them pretty impressive for the mid-range. Build quality was quite good.
I have had a fair amount of drivers (yes, I do have a problem) and I am very impressed with the TangBand build quality and capabilities for the money.
Old 7th February 2018, 04:31 PM   #18
frugal-phile(tm)
planet10's Avatar
I like the plastic baskets… less ringing compared to aluminum or steel. One does need to be careful with the screws (but that is the case with all drivers — too tight is not good). The new Pluvia baskets improve the tech.
The CHBW is really a midbass… the top end is purposely shelved down about 15 dB at 5kHz.
dave
Old 7th February 2018, 05:04 PM   #19
majerjack is offline majerjack  United States
My two cents:
I never heard and know nothing about the CSS FR125S, so please read my comments in light of that fact. I own and have directly compared these drivers to each other: Tang Band W8-1808, W5-1611, W5-2143, Markaudio Alpair 10P, Alpair 10 Gen. 2. I have tested them both on a 48" X 48" baffle and in a variety of cabinets, all within one meter listening distance. Since the W8-1808 is an 8" driver and requires a fairly large cabinet, I think we can discount that one for your stated usage.
All of these drivers produce what I would call acceptable sound quality, but my favorite, the one I think has the best tonal balance both on and off axis, is the Tang Band W5-2143. It models well in a small bass reflex cabinet, but the limited Xmax restricts the bass output. If you can live with that limitation you will be rewarded with a driver that produces a smooth and detailed sound that is equally superb at both lower and higher volume levels.
Old 7th February 2018, 05:12 PM   #20
chrisb is online now chrisb
Steve - for that close a listening distance, I'd suggest either the Alpair6P, or Fostex FF85WK. The latter is a bit more forward and dynamic in the mids, but in a nearfield application punches way above its weight class. I run a pair very compact pair of boxes with little Topping TP30 amp .
I've heard the FR125, and as Dave noted earlier, it was a helluva driver 10yrs ago, but there's more from which to choose these days. Of course there'll be lots of other suggestions - careful what you ask for, analysis paralysis is almost guaranteed at least once in a while .
like my mind, this space intentionally blank
CSS FR125S 'fullranger' anything comparable?Hide this!Advertise here!
Amp comparable to the Marantz PM-68 FuzzyBastard Solid State 7 8th January 2017 10:07 PM
what's comparable to the ppi art amps? havieri23 Car Audio 2 22nd April 2008 05:07 PM
Something comparable to a Quad 405? PoorSound Solid State 0 23rd January 2006 03:19 PM
