Alpair 6M for Cyburgs Needle / BR M.A. Design
Old 6th February 2018, 06:14 PM   #61
grahamgraham is offline grahamgraham  United Kingdom
grahamgraham's Avatar
I like the sound of a big puffy mass...
OK, I will try on the weekend to remove the old wadding and insert newer fluffier masses. Tho, I wonder if it would be beneficial to start again with ply?
Originally Posted by planet10 View Post
The structure you want is no structure… one big puffy mass.
Here is what 40g of acoustastuff looks packaged/teased
dave
Old 6th February 2018, 06:32 PM   #62
chrisb is offline chrisb
Don't look here for an argument against using decent Baltic Birch plywood. A trick of another designer of similarly configured enclosures - and I think Scott wouldn't mind saying one that's been around for decades - would be to make the rear panel removable on cleats to allow easy access to adjust amount & distribution of fill.
And even on something as compact as these, a little bracing never hurts
kinda burnt out - taking a break
Old 6th February 2018, 06:43 PM   #63
I'm starting to regret my shortcuts!
If I add cleats surely I will change the cross-sectional area and volume of the design, tho?
Old 6th February 2018, 07:05 PM   #64
I just had a thought... (Danger zone)
If I jigsaw out a very straight rectangle from the rear I could use the cut out and mount it to another panel so it could fit back in being secured by screws around the edge. Poorly doodled image attached.
I could put foam tape on the seems.
Old 6th February 2018, 07:49 PM   #65
I don't think the slight decrease in total CSA / volume from adding cleats wouldn't be significant enough, but if concerned, your idea could certainly work. The cleats on Pensils above were 18mm square, and they also incorporated closed cell foam weatherstripping tape - not shown in the photo.
Old 9th February 2018, 02:37 PM   #66
I have reassessed the fluffy mass and plumped for a fluffier filler. Hopefully once I have this in the issues will be solved.
I listened to the port very carefully with my ear to it and I could hear clear vocals. I guessing that once I get the stuffing right it will have a knock on effect to the other frequencies?
When listening to TV with them voices are very boxy and resonant with a dip somewhere in the upper mid (?).
Old 9th February 2018, 06:13 PM   #67
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
The pipe produces a ripple train. You want to preserve the lowest one and get rid of the rest. The restricted terminus, driver off-set and damping are all tools to create the low pass filter at the terminus.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Alpair 6M for Cyburgs Needle / BR M.A. DesignHide this!Advertise here!
Cyburgs Needle kit ebijma Full Range 5 13th October 2007 11:53 AM
Cyburgs-Needle and Cyburgs-Pipe for FRS 8 Cyburgs Multi-Way 20 2nd October 2007 09:24 PM
Cyburgs-Needle using W3-315SC mariusn Full Range 35 27th January 2007 06:56 PM
