Alpair 6M for Cyburgs Needle / BR M.A. Design
Old 26th January 2018, 06:27 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
If I braced the side panels could i squeeze them down to 12mm?
12mm would do fine… bracing always helps but you’d probably be OK without it. A holey brace, that also braces the driver to the back of the box would be worth going for. You’d want to increas e width by 8mm to account for the volume of the wood in the brace (assumming 30-40% holes)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th January 2018, 06:30 PM   #22
chrisb is offline chrisb
whence these names, Scott? At the least I'd expect a Sasquatch to be to a larger beast that this
like my mind, this space intentionally blank
Old 26th January 2018, 06:35 PM   #23
frugal-phile(tm)
planet10's Avatar
They may be diminuative, but like the FH-Lite close your eyes and they sound big.
dave
Old 26th January 2018, 09:32 PM   #24
grahamgraham is offline grahamgraham  United Kingdom
grahamgraham's Avatar
Maybe because they stand erect?
Old 26th January 2018, 11:07 PM   #25
I dunno - any reputed photos I've seen of the mythical man-beast of the wilds shows it hunched over somewhat. At least the Giraffe for A5.2 made a little bit of sense - tall and skinny from the neck up - but of course, no legs.
Just being silly.
Old 27th January 2018, 08:23 AM   #26
Thanks, I will have a good think about how to go about it.
Is the height and position of port the most crucial element to this deisgn? Eg, you mention increasing width to accommodate the brace, can it be thinner/ deeper as well? The port would change by 8 mm width.
But like you say, this may be academic as bracing isn't essential.
Thanks to Scott as well!
dave
Old 27th January 2018, 08:57 AM   #27
frugal-phile(tm)
planet10's Avatar
I’ve updated the drawing & link in my earlier post. Scott did specifiy a Zvent, but that goe sout the window with th eslot vent.
You can change the aspect ratio as long as the net cross-section remains at 13cm2. Don’t make it too skinny (early reflections leed to cupped voices) or square
You have to take care with the slot vent version if you change aspect… the length, width & height of the vent all change.
dave
Old 27th January 2018, 10:10 AM   #28
That's brilliant, thanks!
What does look appealing to me is to switch the depth and width around to 118mm deep by 110 wide as per the original spec. Sorry to trouble further but if I went with the slot port how would I change the port dimensions? I take it that the width of the panel making the slot is part of the length of the port?
dave
Old 27th January 2018, 10:13 AM   #29
frugal-phile(tm)
planet10's Avatar
Easiest to just leave it and fire it out the side… its time to go to bed (03:15 here), do you want it out the front and 12mm with a brace?
I can figure that out tomorrow.
dave
Old 27th January 2018, 02:44 PM   #30
12mm with no brace fits my implementation best as I will be using the higher mounting position for the driver and at that position bracing will be ineffectual. Am I right in assuming that?
Wow, you're up late bro, rest! And if you do have time for the slimmer 12mm non braced slot port version at 110mm wide I would be bowled over, thanks for all the work so far!
dave
Alpair 6M for Cyburgs Needle / BR M.A. DesignHide this!Advertise here!
Cyburgs Needle kit ebijma Full Range 5 13th October 2007 10:53 AM
Cyburgs-Needle and Cyburgs-Pipe for FRS 8 Cyburgs Multi-Way 20 2nd October 2007 08:24 PM
Cyburgs-Needle using W3-315SC mariusn Full Range 35 27th January 2007 05:56 PM
