Jordan Eikona 2
Jordan Eikona 2
Old 11th January 2018, 12:29 AM   #21
perceval is offline perceval  Taiwan
perceval's Avatar
Originally Posted by mkane77g View Post
Thanks. sorry for the stupid question. My An 10's are .23 so the Jordans are actually a better choice for OB.
Qts of a full range driver is not so relevant in an OB design if you are going to support it with a woofer for bass duty.
Old 11th January 2018, 12:32 AM   #22
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Jordan Eikona 2
All depends where you are crossing over and how big your baffle is. I would opine that the Eikonas probably sound better (i’ve not heard them yet).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th January 2018, 12:34 AM   #23
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Depending on how low you want it to go and how you are implementing it it has high excursion, not that I'm a big fan of that though, I crossover at 130 Hz and just about manage without any EQ
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 11th January 2018, 12:47 AM   #24
mkane77g is offline mkane77g  United States
Always Learning
Jordan Eikona 2
These will get a trial run in NP SLOB. Mini DSP HD ordered. Crossed @ 80Hz. Mr. Pass says to skip hertz from 80 and go directly to 160Hz.???????????m I'll use the AN's upstairs or out in the garage. I have 1808 coming also. Speaker rabbit hole!!
Old 11th January 2018, 04:22 AM   #25
perceval's Avatar
Well, I'm sorry, but no amount of Qts will let a 4" driver play down to 80Hz in OB. Even 160 is pushing it.
I'm a big advocate that if you have a nice big woofer to help, why not really let it help the often smaller full range driver so it doesn't have to struggle playing down low, and frees it to cleanly play the higher frequencies.
I will often XO in the 250 to 400 range depending on the curves used.
Old 11th January 2018, 01:25 PM   #26
Always Learning
Jordan Eikona 2
Can't x over that high in this SLOB. I'm going to set this up so that the Jordan come on after 160Hz. And if that doesn't work I'll make an H frame or a Z frame for the woofers.
Old 11th January 2018, 01:37 PM   #27
Baffle size and shape not driver size is the main deciding factor. Also bare in mind that the dipole cancellation doesn't happen in the real world quite so simply, you need to take into account distance from front wall and reflections. Crossing over at 160 Hz is perfectly doable
Old 11th January 2018, 02:09 PM   #28
Always Learning
Jordan Eikona 2
I thought baffle size wasn't a huge factor with the FR driver.
Old 11th January 2018, 02:16 PM   #29
It will determine (to some degree) where the dipole cancellation begins, exactly the same as it does with a bass driver
Old 11th January 2018, 04:13 PM   #30
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Actually, assuming the driver has a sufficiently low Fs & reasonable Qt, there's no reason why it can't play down to 80Hz on an open baffle. It just won't do it very loudly.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Jordan Eikona 2Hide this!Advertise here!
Jordan Eikona 2 Designs Steven-H Full Range 113 22nd April 2018 03:02 AM
Jordan Eikona 2 VTL enclosure sheiron Full Range 16 27th January 2018 10:03 PM
Jordan Eikona 2 stonehome Swap Meet 1 25th July 2017 11:48 PM
Experience with the Jordan Eikona Kevin Warne Full Range 45 19th March 2015 05:21 PM
Experience with the Jordan Eikona Kevin Warne Full Range 0 5th February 2013 10:24 AM
