Choosing driver's
Choosing driver's
Old 2nd January 2018, 11:55 PM   #11
Dr1v3n is offline Dr1v3n  United States
But as far as looking at a spec/datasheet, maybe some warning signs would be dips or peaks between the critical 1kHz-7kHz range. Especially dips or peaks at multiple harmonic frequencies or even larger dips or peaks at a single frequency.
Also, a higher efficiency driver at a cheap price might be a warning sign. Probably should be used in a multi-way speaker config instead of full range.
Old 3rd January 2018, 01:15 PM   #12
midrange is offline midrange  United Kingdom
Choosing driver's
I am a great fan of Monacor drivers, but not so much of the full range ones. Mark Audio are not so easy to source in the UK. The 3" Faital Pro full rangers are very cheap and surprisingly good. For very little money you can experiment and learn.
Old 3rd January 2018, 06:30 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Choosing driver's
I don’t think that is true. A distributor in Warwickshire. http://www.kjfaudio.com/
They also sell flat-paks. FHXL for instance likely more available than anywhere else.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th January 2018, 08:49 AM   #14
Choosing driver's
Originally Posted by planet10 View Post
I donít think that is true. A distributor in Warwickshire. http://www.kjfaudio.com/
dave
Thank you for that information. A very useful site. Happy to be corrected.
Choosing driver'sHide this!Advertise here!
help choosing 18in driver codycale PA Systems 4 13th October 2012 02:05 PM
What is most important when choosing driver? Starre Multi-Way 36 23rd June 2012 07:38 PM
Need help choosing a driver and a horn design. italynstylion Full Range 27 10th February 2009 12:28 AM
Help choosing midrange driver Kittle Multi-Way 17 14th October 2004 07:21 PM
Choosing a sub driver based on T/S... manxam Multi-Way 2 21st February 2004 10:16 AM
