Golden ratio bass horn
Old 30th December 2017, 12:55 AM   #21
GM is offline GM  United States
GM's Avatar
Originally Posted by planet10 View Post
GM, if you can point out what dimensions you need i will measure that. Horn is 2 small straight sections and 3 circlular sections.
dave
Can your program tell if it's expo, etc.? Regardless, every 3" like shown is plenty good enough and for this horn, maybe every 4" in the last, larger expansion. Once these are known it can be broken down into flat panels to 'trip up' its excessive HF.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th December 2017, 01:27 AM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I can only generate dimensions. 3 apart (at at least 1 end anyway) except where shown. The horn is primamrily formed by 3 circular sections shown in blue, red, purple.
Golden ratio bass horn-grhorn-detail-png
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th December 2017, 01:46 AM   #23
GM's Avatar
OK, can you factor in the width to make each 'slice' an area dimension? Also, too little info [for me] to figure the area expansion for the circles. We need somebody with AutoCad......
GM
Old 30th December 2017, 02:14 AM   #24
frugal-phile(tm)
planet10's Avatar
I’m pretty sure my CAD software can do anything AutoCAD can… operator thou is not up to expert level.
dave
Old 30th December 2017, 02:19 AM   #25
globalplayer is offline globalplayer  Germany
globalplayer's Avatar
So it is a pi horn and not phi.
Old 30th December 2017, 06:50 AM   #26
GM's Avatar
dave
Know that problem well, tried to learn AutoCAD in the '90s with zero help and before I got on-line and finally gave up as way too tedious plus the manual apparently assumed I'd taken a course in school.
GM
Old 30th December 2017, 04:47 PM   #27
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
There’s a parametric curve genrator function. In Solidworks, you can place an image in your sketch plane (from a math plotting program or photo) as a visual guide and use several splines to fit any complex curve you like without entering an equation.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 30th December 2017, 08:30 PM   #28
GM's Avatar
Thanks!
Hmm, couldn't find a price, so assume only DIYers with 'deep pockets' can afford it.
GM
Old 30th December 2017, 09:02 PM   #29
frugal-phile(tm)
planet10's Avatar
I believe SolidWorks is in the thousands of dollars/seat. The sw i use is just over $1000.
dave
Old 30th December 2017, 09:38 PM   #30
GM's Avatar
Thanks! ...like I said....... Oh well, if you can give me enough 'pie slice' areas, I can try empirically finding a 'close enough' flare frequency, factor if it is indeed near enough expo.
GM
Golden ratio bass hornHide this!Advertise here!
Golden Ratio vs Tower - what should I do? Nvr2manybikes Multi-Way 21 8th April 2013 05:11 PM
golden ratio. I dont get it murphythecat8 Multi-Way 84 14th December 2012 04:04 AM
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 09:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 10:52 PM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 09:40 PM
