Golden ratio bass horn
Old 25th December 2017, 12:00 AM   #11
GM is offline GM  United States
GM's Avatar
At a glance, it constitutes a simple offset driver pipe horn and since curves are used over most of its expansion it could be a 'golden ratio' flare even though it has parallel sides, with the downside that these cause a 'train' of eigenmodes along its length [AKA 'slap'echo'] like in a typical parallel wall room.
Without a whole lot of measurement points, no way to easily figure it's actual flare, axial length, hence do any sims unless a drafting program can work with less: https://i.pinimg.com/originals/51/0e...b2c395b744.jpg
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th December 2017, 12:32 AM   #12
Walloffound is offline Walloffound  United States
Walloffound's Avatar
Is there a way to minimize this slap echo effect, like maybe putting a non reflective material on the parallel sides
Old 25th December 2017, 12:44 AM   #13
freddi is offline freddi  United States
freddi's Avatar
probably something like 3/8" felt - a piece at the top bend - maybe something in the "chamber" - then perhaps one sidewall. P10 and GM would know better than myself.
Old 25th December 2017, 12:47 AM   #14
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
If it were truly a golden ratio, it would look like a Fibonacci spiral (a Nautilus) and wondering why the math teacher did not make a curved inner wall if he made a full curved outer wall?
See the resemblance?
Golden ratio bass horn-04168c3d-244c-41e2-8560-ea536f4695a8-jpeg
File Type: jpeg 04168C3D-244C-41E2-8560-EA536F4695A8.jpeg (61.7 KB, 277 views)
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 25th December 2017, 01:29 AM   #15
My guess is to shave a foot + on the depth ?
Old 25th December 2017, 03:58 AM   #16
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Good clue X.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th December 2017, 06:23 AM   #17
frugal-phile(tm)
planet10's Avatar
Drawing in post #8 updated.
GM, if you can point out what dimensions you need i will measure that. Horn is 2 small straight sections and 3 circlular sections.
dave
Old 25th December 2017, 08:54 AM   #18
That looks good Planet10, nice work. I can also take more precise measurements such as the midpoints of the circular sections
Old 29th December 2017, 11:04 PM   #19
mods or recommendations welcome
Old 29th December 2017, 11:11 PM   #20
frugal-phile(tm)
planet10's Avatar
Phase plugs for the drivers, basket damping — and/or more radical mods.
dave
Golden ratio bass hornHide this!Advertise here!
Golden Ratio vs Tower - what should I do? Nvr2manybikes Multi-Way 21 8th April 2013 04:11 PM
golden ratio. I dont get it murphythecat8 Multi-Way 84 14th December 2012 03:04 AM
The Golden Ratio Stage Stee Solid State 7 22nd February 2009 08:46 PM
Golden Ratio Height edjosh23 Full Range 13 3rd February 2009 09:52 PM
Golden ratio - Example? icebear Multi-Way 5 17th April 2004 08:40 PM
